Wtt slash roller for exo terra buggy roller
As the title sais I want to trade my slash 2wd for an axial exo terra buggy roller. Slash has rpm arms all around rpm bearing carriors rpm castor blocks. Traxxas aluminum linkages all around. Strc aluminum bellcrank with bearings. Brand new transmission case and all new transmission gears. Comes with a 90 tooth spur and a 86 tooth spur a 25t pinion 23t pinion and a 19 tooth pinion. All for 5mm shaft. I would like to keep the wheels and tires unless the exo will come with a set. Stock tires are fine. Slash will come with no electronics. Rpm bumpers front and rear also. Two bodies, stock rapter body(white) and a proline desert rat needs new paint. The paint on the desert rat is flaking off. Both bodies are well used. Cracked in the rear corners. Also has the proline chassis saver. All it needs is the rear body post. Both rear posts broke off and a bad flip. Other then that this truck is indistructible. One last thing yes more upgrades on the slash. Steel cvd style drive shafts and aluminum rear axil carriers. The truck has been both on road and off road so there is scraches on the skid plates. I beleave that is it. Let me know what you got. pm me for pictures. In the process of cleaning it now.
Price: 325. Price is firm. I can include the original recipt for tje truck and the recipt for the third motor and esc.
dude no one in there right mind would do that trade
guess its a good thing i traded it locally for a rtr losi mini crawler and an ofna jammin x1 crt 1/8 truggy with the rc monster brushless conversion and a momba monster system and two lipos. only things needed on the jammin was a shock shaft and a wing mount a servo and a rx and tx. so i got a better deal. nothing is impossible, you just have to wait for the right time. i am now trading the mini crawler for a blade cp pro and another 1/8 brushless system. thanks for looking tho.
