What is your favorite 1/8th on-road body?
The Proline Lola has been around for a while and alot of guys run them but I have been hearing alot about the Whip and the Dome. Have you tried them all and what is your favorite? Which one has more steering or rear traction or easier to drive?
the whip is the best for wide open tracks and dome for tight technical tracks lola good al aoround
i have run the protoform and the whip, but my favourite is the blitz body.
Mark
Originally Posted by Winner's Circle
I am currently running the Parma Audi R10 and I really like it. It is better than the Protoform Lola or the Parma Audi 03. I tried the Dome briefly (borrowed from a fellow racer) and it handled very much like the Audi R10 on our track.
Hope this info helps.
are you using the proper body mounts, there are long and short ones, not to insult your intelligence, but thats a mistake commonly made.
Originally Posted by quietstorm76
I'm running the Parma R10 on a MRX4 but I can't get it low enough in the front. This is giving me a push. But overall the R10 handles very well.
Paul
Originally Posted by chicky03
I have the short body mounts with a spacer and the graphite body mount. I also ground the top of my tower to get the body as low as possible. It is the R tower. Right now it touches the tower and top of the bumper. I did this at the nationals and it made a pretty good difference.
Paul
Paul
I'm using the long ones but when I move the body forward like I want it hits the front shock stay. Maybe I'm doing something wrong but I didn't have that problem when I ran the Kyosho Dome.
Paul
Our body has the front vents to cut out so the body is lower in that area than the Dome. Right now my body is mounted with the front holes cut using the front dimple on the body with the body mounts twisted forward. I do need to trim the front of the body up slightly so it does not drag. Just do what ever it takes to make the body lay on the bumper. I am pretty sure my body is 13mm from the bumper to front of the body on the MRX4R.
Paul
Paul
I mount it the same way............all I can say is the Parma R10 kicks ARS!!
I mounted the R10 body 5mm forward on my Serpent 960 and my post are almost too short. I have always mounted all my bodies 5mm forward. With the Audi 03 and the protoform lola mounted in this manner I ran the rear air dam either down or 1/2 the way up but the R10 has so much steering that I run the rear air dam all the way up now.
Paul
Paul
