Set Screw for Mini T motor gear wrench size
Anyone know the right size wrench for the Mini T motor gear? The screw looks like its a M3 screw with a hex cut into it. I dont have anything nearly that small so i need to order something that i can use to screw it down. Any suggestions?
Probably 1.5mm. Run to your local hardware store and see if 1.5mm fits
Mini T Pinion Size
