Need some help with my Team Magic G4rs
Went to go run car today, made a few passes and then car just stopped moving. Engine revs but no movement. I thought maybe clutch was to tight so I decided to adjust it but ring will not spin to the left to loosen it up. Any thoughts or suggest would be helpful.
Did you strip your spur gear?
NOTE: The Clutch spring retainer screws on with the flat side against the spring, not the side with the lip.
Sorry I have not had a chance to mess with the car in about week or so, I will give all the above a try and see what i get, thanks for the replies.
note: This happened to us, check you havent left too much fuel line and it may have been nicked by the spur and leaks fuel onto 2 speed.
