Sprint 2 Flux body questions
Can You put any 200mm body on the car regardless of who makes it?
What about the 190"s??????????
Just about any 200 or 190 mm body should fit fine. If you are using a 190, you just need to use 24mm tires with no offset(standard TC tires like Sorex, Solaris, Sweep, etc). The 200mm bodies just need wider/offset tires to look right, like the vta tires your sprint 2 flux came with.
Some of the bodies with lower front ends might be a bit of a pain to fit. You may need to chop the front inner posts to drop it down enough. Or take the outer front posts off and use body pins under and over to hold it.
