Hotbodies D817 Nitro thread
#421
Folks, just building a V2. When trying to attach the steering linkage to the aluminum Servo saver arm, what kind of nut do you use on the bottom ? The one it says to use won’t fit into the machined slot under the Servo saver arm.
Thanks.
Thanks.
#422
D817
I used the one that its says to use I just used a longer Screw and Tighten the screw up to pull the nut in Place than I put it Together
#423
I sold my TLR 4.0 to get into electric and the HB E817 is what I plan on getting. I assumed if the nitro is getting a face lift then it only stands to reason the Ebuggy would get one. Don't know if it needs any improvement. (I've heard nothing but good things about the ebuggy.) But, isn't the E817 the first 1/8 Ebuggy developed by HB? Also since it's raining and there's no 1/8 racing I might be better off waiting to see if the E817 gets the v2 upgrade before I buy.
#424
Are people running the shorter tower to lock down the rear end a Bit more on loose tracks?
#425
Yes. I recently Installed the short tower on my nitro buggy. I ran for the first time at SIC. It was the best nitro buggy I've ever driven. Last night, I tried it for the first time on our local track it was good there as well. As far as difference in the regular tower, I would say had more rear grip, but at the same time, it was much more agile and easier to drive at the same time. I also tried it on my ebuggy last night. My ebuggy was super fast, but kind of loose if the track wasn't perfect or if I didn't have my best tires on it. With the new tower, it had tons of rear grip and was super easy to drive. I did notice it lost a touch of off power steering with the added grip, but before, I had 35wt oil front and rear. This time, I just threw on the nitro rear shocks that had 32.5. I think with a few minor changes, it should be just right.
#426
V2 vs Short Rear Tower ?
Guys, I’m new to HB. Coming from the AE cars.
I just built a V2 and am wondering is the new rear tower/shock setup on the V2 the same as what everyone is calling the Short Rear Tower ?
#427
#428
From what I understand, it is a little taller and narrower. It allows you to run the same shock bodies with D8T shock ends. The low carbon tower requires different shock bodies. I will have a V2 tower soon to test.
#430
#432
Everything should fit besides the D block.
#433
You use the included buggy rear shock bodies with the D815/817 with the D817 V2 aluminum rear shock tower.
you only use the D8 Truggy front shock bodies with the short carbon rear shock tower.
The v2 tower was to give more movement in the rear shock for better bump absorption so you need the the longer stock shock bodies.
#434
It falls in between the d815/17 and the short carbon rear tower.
#435
Got a few new in package parts for the D817 for sale in for sale forum. Mp9racer
