TC3 Forum
#5491
Milled chassis
Hey guys,
I should have 8 Graphite chassis shipped to me this week to be milled. 3 of the 8 are already spoken for. I am hoping to have them back and ready to ship in about 7 to 10 days from now. PLease e-mail me if you want one and I'll hold one for you!!
Thanks,
Ray
[email protected]
Thanks,
Ray
[email protected]
#5492
Help guys!!
I just a new FTTC3 to replace my tired old one and its got the new white gears. I have a bunch of the old Grey gears all broken in-all in perfect condition. I run stock and sometimes 19 turn-no Mod. Which gears should I use-Grey or White for best speed and efficiency?
Thanks,
Ray
Thanks,
Ray
#5493
Originally posted by rayhuang
Help guys!!
Thanks,
Ray
Help guys!!
Thanks,
Ray
#5496
Ray,
Run the grey gears. The white gears were the first batch of replacements and a prone to breaking. Probably would never break either gear in stock or 19 turn but at least you'll have peace of mind. Btw guys... Buy the chassis from Ray! You won't find a better milling job for the money. I got one earlier this year and love it. Balances the car and makes it feel more planted to the track.
#5498
ray, how much do you charge for one of those chassis'?
also, roughly how much would international shipping be (to Australia)?
thanks
thanks
#5499
Originally posted by TigeRyan
Mike D, sorry for a possible silly question, what was the surface that setup was for? Rubber / Foam tires?
#5500
Originally posted by Johnnytc3
hey mike good to see your winning setup, what do you use for toe in/out for front and rears, and did you mill your chassis all the way to the middle or just about .1 inch?
thanks again
thanks again
I milled the chassis so the batteries were 1mm away from the driveshaft when mounted in the foward battery position.
#5501
hey guys
i heard that the "team" cars now come with an aluminum center shaft.
is this accurate?
is this accurate?
#5502
I'm pretty sure they do. But only the new edition team kits will. The old ones have that composit or graphite shaft. Personally I like the composite and graphite shafts for stock better because they're lighter.
#5504
Registered User
#5505
chassis modification
I was wondering if most were running the car with the battery tray mod in order to get the batts closer to the center line or are they running the chassis stock.Want to know the benefits to running it closer to the centerline in handling and what are the factory guys doing.I know cyrul is running his car like this.Anyone else?Thanks guys!
