Roche Rapide F1 EVO3
Announcing the newly re-designed Roche Rapide F1 EVO3 car kit. Major features include-
- New design graphite main chassis, rear pod plate, front lower arm, caster adjust plate, top deck, chassis brace
- New design aluminium rear bulkheads and lower pod plat with centering pins
- New design aluminium motor mount and rear bulkhead with plastic axle ride height adjusters. Red/Black two tones anodize.
- New design 7075 aluminium floating servo mount and main chassis, lower servo position.
- New design graphite multi-flex top deck, adjustable chassis flex by special tweak free screws. Center damper positions adjustability on top deck.
- New design center pivot system. High / lower pivot position adjustability.
- New DVS-V3 center damper. Quick rear droop adjustment.
- New 7075 aluminium easy adjust side spring holder.
- 152022 Roche Rapide F1 EVO3 1/10 Competition F1 Car Kit
- 152023 Roche Rapide F1 EVO3 1/10 Competition F1 Car Kit, USA Spec
Can't wait for this to come out.
looking forward to it.!
So here's the $64 question. Will we be able to take the new pod and put it on the EVO 2?
Your ideas are great, I'm looking forward to your results
1x 210274 Rapide P12 EVO2 Center Pivot Mount Spacer Set, 0.5/1mm <-- Evo2 optional part that you might already have
1x 210279 Rapide F1 EVO3 Aluminum Center Pivot Ball Mount
1x 210280 Rapide F1 EVO3 Aluminum Lower Pod
2x 210282 Rapide F1 EVO3 Aluminum Motor Mount / Rear Bulkhead
1x 220218 Rapide F1 EVO2 Graphite Rear Pod Plate <-- you should already have this
1x 220281 Rapide F1-EVO3 Graphite Chassis Brace
finally you'd need the axle holder -- not sure which best works depending upon ride height goals--
240175 Axle Height Adjuster, OP Version (0.75)
240176 Axle Height Adjuster, OP Version (1.00)
240177 Axle Height Adjuster, OP Version (1.25)
I asked Max Ma of Roche and he provided a list of parts that would need to be swapped in order to just change the motor mounts from a Evo2 to Evo3. it isn't as simple as buying two motor plates.
Could anyone tell me the length from the bottom of the diff side (where it meets the axle bearing) to the outer edge hex hub mount? (not counting the axle threads)
I did put the floating servo mount on my Evo2, as well as the new top deck - I think it removes several areas that can cause temporary chassis tweak. FYI - the servo mount will move the servo forward about 5mm.
