MR4TC BD vs. FK 05 vs. 415  MS >
Old 05-25-2005, 02:24 AM
asw7576's Avatar
Default MR4TC BD vs. FK 05 vs. 415 MS
which one do you think it's the king of asphalt ? Money no object.
asw7576 is offline
Old 05-25-2005, 02:56 AM
ogreasurada's Avatar
ogreasurada is offline
Old 05-25-2005, 03:04 AM
i think should be BD...
tsuiyuen is offline
Old 05-25-2005, 03:14 AM
the 415 is no longer in production so unless you can pick up a good used one or find a store that still has them instock this car is pretty well off your list.
the FK05 is a great car, have owned one & is quite easy to setup, the second production units are hitting stores so the thrust bearing issue should now be solved ( although i never had an issue with this) FK05 would be a good choice.
MR4TC-BD is also a great car, very free driveline= speed & does handle well, mind you i have only driven the car once & was not completly setup to my liking. having said this my lap times where only half a second off the top runner's ( if only i did not have issues with two servos
end of the day it's your choice
flysti is offline
Old 05-25-2005, 03:25 AM
highwayman's Avatar
BD ... most dialed in car.
highwayman is offline
Old 05-25-2005, 03:26 AM
Jack2's Avatar
415MS all the way, sweet looking car and....... well Its the World Champion Absolutly awesome car.
Jack2 is offline
Old 05-25-2005, 03:43 AM
ttso's Avatar
When you need rush replacing belt, replacing diff, you will find 415 is totally a nightmare and BD is just like a sweet heaven...
That's the only complain I have for 415...
ttso is offline
Old 05-25-2005, 04:49 AM
fastolfart's Avatar
They are all great cars, I had run x rays for the last 5 years and decided it's time for a change, bought the Yokomo BD and am absolutley loving this car.
So my pick would be the MR4TC-BD
fastolfart is offline
Old 05-25-2005, 04:54 AM
Burlap's Avatar
Yeah? Tamiya seem to still advertise it on their site. Although I wouldn't trust their site 100%
Burlap is offline
Old 05-25-2005, 05:07 AM
TryHard's Avatar
agreed, pretty sure the MS is still in production....
TryHard is offline
Old 05-25-2005, 05:16 AM
Jack2's Avatar
Well I contacted tamiya a little while back, and the only word was the TRF415MS was a LE kit and it would only be in production for a certain amount of time, but the standard 415 was still going to be continued.
Jack2 is offline
Old 05-25-2005, 05:17 AM
Jack2's Avatar
But now I think the MS version has been discontinued.
Jack2 is offline
Old 05-25-2005, 08:35 AM
edseb's Avatar
Be careful too, from a lot of drivers, I've heard the 415 tweaks real easy. Needs to be loosened on the bottom and reset after the smallest of hits; like hitting a dot. No way to solve this since there are so many decks and support tubes. It's a good driving car, but tweaks easy.
edseb is offline
Old 05-25-2005, 08:50 AM
Regional Moderator
daniz24's Avatar
The SDW and FK05 are also having this nightmare problem just like 415...
daniz24 is offline
Old 05-25-2005, 09:15 AM
edseb's Avatar
If you like those car layouts, you should look at the Corally RDX. It's dialed and solid as a brick with almost no tweak.
edseb is offline
