Castle Creations Mamba Max Pro Sensored ESC
#361
the new tekin software is like the mambas software with the cheat mode but it also has a turbo feature. it will be tough to tell but i think the mamba should be able to keep up. just need people to post there set-ups that they are running with the mmp and all find a sweet spot and continue trying to figure out the setting for the most power.
i have a question is anyone running the max timing in cheat mode?
also i tried to use the custom feature on the rpm to set it to 4k-7500k and it gave ma an error message and wont let me do it? i am going to run 17.5 with it what is a good setting if i were to run 50 on timing? should i run my fdr around 6 for a 50x80 track with this setting?
#364
well if 2day was any barometer, the castle still has its way with the tekin.
R
R
#366
17.5 TC @ 5:1.
set rpm to track size. duo motor 0 Timing. 30 pills from the castle.
pretty sad when a 'TEAM DRIVER' for another speedo manuf and his father try to tell castle runners today that the esc is illegal. especially after pasted by it despite fact that they run 13.5 MUAHAHAHAHA.
R
R
#368
already found out that its diff for all tracks and even each driver. u might want it to jump off the corner more than the next guy (even if u lose on at end of straight)....or u can use it as a traction aid if ur gettin wheelspin off the corner.
R
R
#369
This thing is really really fast. I have no desire for any other speedo.
#370
yeh karl and ur gonna bring the pain 2mrw. nothing like doin the biz not only in stock, but in SS with a 17.5. the day of reckoning is upon us and i'm gonna have a front row seat of it all.
R
R
#371
fair enough. sucks i wont be able to try mine until the 16th that is my next race. up here in wa we dont have a permanent indoor carpet track unless you want to drive a few hours to almost the oregon boarder. so the reason why i keep asking for rpm settings is because i have yet to figure it out i thought i would start with the 6k-7.5k for a 50x80 track and cheat set at 45 and ballistic 17.5 at 30(neutral factory setting) and fdr at 4.5
#373
might sound crazy, but try retarding your motor timing on a tight track
R
R
#375
Motor stays pretty cool too, once I figured out the gear its consistently coming off at 160*
