Hyper TT 4wd 1/10th Truggy Thread >
Like Tree48Likes
Old 10-19-2011, 03:30 AM
  #3181
Read this PDF.It's true...
I use only 5.5mm bullet connectors and hardwired motor/esc.
You don't have to buy original EC5(they are expensive and hard to plug/unplug).Just get some high quality 5.5mm bullet connectors.
@RacerX20 Nice truck! I have the same battery.
You are right about the batteries.Turnigy has the best lipos.
File Type: pdf
AL3xGR is offline
Old 10-19-2011, 09:10 AM
  #3182
FangsCPO's Avatar
Originally Posted by macnkitty2002
I run a Caste Creations Short Course brushless setup in my TT. I use a Venom 7.4v 20C (2S) 4000mah battery pack. I have noticed that the speed control overheats and will occasionally shut itself down momentarily. However the battery is not hot at all. Motor temps are fine.
Does this mean that I'm not running a powerful enough battery? I liken what's happening to an analogy. Suppose you are drinking a soda with a straw, but the straw is a coffee stirrer. Of course you will strain to suck up the soda with such a tiny straw. However if you have a bigger straw then the job is much easier. I compare the person drinking the soda to the ESC and the soda in the cup as the battery.
I think I need to run a higher C-rated battery, could this be the case? If so, what do you all suggest I run? I'd like to up my voltage if I can. I believe the CC brushless setup will accept up to 11.1v if I am not mistaken.
Help would be appreciated!
Thanks!
You need 40C at a minimum. Try these, it may required a slight battery tray mod because of the wires but very good lipo and inexpensive.
http://www.hobbypartz.com/98p-40c-50...se-direct.html
FangsCPO is offline
Old 10-19-2011, 10:49 AM
  #3183
elex300's Avatar
Trader Rating: 110 (100%+)
I'm adding diff fluid to my 10tt. Are you supposed to clean the grease off the that comes on them from the factory?
elex300 is offline
  #3184
ps71's Avatar
Default My new toy....
Just finished up my tt....
Put in a hobbywing 120a esc and 2700kv motor.
Turnigy 3s 4500mah 35-70c battery
Strc rear hubs, top plate and diff mount
Changed out the grease in the diff witth 5k center and front and 2k back.
Proline holeshot.
Savox 1258tg servo
15t pinion
Just tested it for a little bit and i`m impressed
Attached Thumbnails Hyper TT 4wd 1/10th Truggy Thread-dscn0791.jpg   Hyper TT 4wd 1/10th Truggy Thread-dscn0787.jpg   Hyper TT 4wd 1/10th Truggy Thread-dscn0792.jpg
ps71 is offline
Old 10-19-2011, 10:55 AM
  #3185
elex300's Avatar
Very nice! Putting mine together right now. Will post pics when done.
elex300 is offline
Old 10-19-2011, 03:10 PM
  #3186
NofriendsTaco's Avatar
Trader Rating: 53 (100%+)
What i got got far...
NofriendsTaco is offline
Old 10-19-2011, 03:32 PM
  #3187
RacerX20's Avatar
^Nice! Where did you get those aluminum front knuckles???
Oh and does anyone know where to get that Losi style motor mount?? There was a few pictures back a dozen pages or so.
-Tony
RacerX20 is offline
Old 10-19-2011, 04:25 PM
  #3188
ps71's Avatar
Did see the knuckles on ebay a while back, never found them in any shops.
They sure look nice....
ps71 is offline
Old 10-19-2011, 09:40 PM
  #3189
Cummins Driver's Avatar
Trader Rating: 19 (100%+)
Hey guys, im looking into buying one of these trucks. However, my question is, what are the differences in this and the hyper mini st-e?
Also, about what kind of speed are you looking at with a 4000kv motor on 2s with stock gearing?
Thanks for any help!
Cummins Driver is offline
Old 10-19-2011, 10:19 PM
  #3190
RacerX20's Avatar
I had a mini STe and the only difference I see is they lengthened the chassis by about an inch, gave it bigger wheels and tires, a new body, and called it 1/10th scale instead of 1/12th. I actually think it's a bit small to be called 1/10th scale, more like 1/11th scale IMO.
Put this in your calculator:
(Battery Voltage) x (motor kv) x (pinion) x (.0029) / (spur)
-stock gearing is 14/42-
This is approximate. It doesn't take into account wind resistance, loaded kv, voltage drop, traction, tire ballooning... ect.
So on a fully charged lipo you're looking at around 32 mph. I've got a 4800kv on 2s with 15/42 gearing and I'm pushing 40mph.
-Tony
RacerX20 is offline
Old 10-20-2011, 06:26 AM
  #3191
Thanks for the quick response Tony
I really like the looks of this truck and am thinking about buying one. Hard to beat the features it has for the price. It would mainly be a parking lot basher, and something of a smaller scale that i could take with me when the family goes on trips so that it doesent take up so much room, plus it only uses 1 battery at a time. My father in law has a Losi Speed-T he takes. I had a brushless stampede, but sold it and am looking for something different. Im either going to go with a new Duratrax Evader EXT2, or one of these i believe. The brushless system will be an EZrun ESC and Tacon 3930kv motor. Id be pretty happy if i could get a reliable 35mph out of it.
Is the motor mount adjustable enough that i could run say a 17t pinion if i wanted to? Also, what pitch are the gears? Im guessing 32 pitch? Thanks again for the help.
Eric
Old 10-20-2011, 06:41 AM
  #3192
1Fastpede's Avatar
Eric
This is much better than the Duratrax. These trucks are so much fun.
1Fastpede is offline
Old 10-20-2011, 07:04 AM
  #3193
I have no doubt it is better than the duratrax. I probably wont beat it real hard. Its not going to be my main beater or anything, and im not looking to put a high dollar brushless in it, so the main advantage the evader will have is that its lighter and probably cheaper to maintain since its less complex.
Old 10-20-2011, 08:13 AM
  #3194
ps71's Avatar
Eric
You can easily fit a 17t pinion on there, the pinions are mod1...
ps71 is offline
Old 10-20-2011, 09:46 AM
  #3195
-Tony
My friends who sold me the truck got the knuckles off a guy who got them CNCed and sold them here on RCtech for $45 I think. Not sure if he still makes him but he sold them on the forum.
