Hot Bodies Cyclone
#3226
I don't have any problem with my diff, but as many people here the head of my diff screw popped off but that happend once and now my diff is fine
Dutch : hey, rcpoint al met je cyclone gereden ?, goeie site he zoveel info
#3227
sanded graphite looks nice to me!
i did that on my oval car once
#3229
Originally Posted by cyclone
on page 102, hara is doing his build tips... at the top hes dremeling some alloy away for the belt and the steering linkages, is this a problem on the original edition cyclones? if so will it be changed on the new ones?
cheers
andy
cheers
andy
#3230
Originally Posted by rcpoint
More specifics about a diff:
After 4 runs diff gets very loose. I've tried almost everything to keep it tight, but no luck.
#3231
Just noticed, that the next segment of Hara's tips are up: http://www13.ocn.ne.jp/~mirage-j/AH/...yclone02.htm#2
#3233
I broke my diff screw again today! When can I get the Titanium ones !
#3234
Originally Posted by SpeedDesignz
Has anyone tried the reversed rear shock mod on thier Cyclone yet ?
I did it to my Pro 4 this weekend and the car rotates sooo much better.
carpet
foams
that is
just want to get some opion on set ups
the belt car may not be far off
carpet
foams
that is
#3235
Used 12x1 motor (orion)
#3236
I have a Cyclone for sale if anyone is interested. (My spare)
http://www.rctech.net/forum/showthread.php?t=106414
#3237
You have PM =)
#3238
carpet
foams
that is
carpet
foams
that is
#3239
I have a delema with my Hot Bodies Cyclone I bought it 2nd hand but its in mint condition only one or two runs on it the problem Im having is when I make a right tight turn it wants to spin out but when it turns left its fine I put it on a MIP Tweak station to see if it was out of tweek and when I looked at the bubble it was dead center I did that for the front as well and it was dead center as well so I looked over the whole car to see if anything was bent or binding up and everthing was fine I ran a brand new set of Take offs CS-27 and it still spins out I ran the same tires on a differnt touring car to see if it was the tires but they where fine to I checked all the shock lenghts and they where fine as well and I checked the sway bars to see if they where bent or binding up and they where fine to I also looked to see if any screws where loose but that was Ok to the setup Im running is the asphalt setup on the back page on only changes i made to the car was I built a front diff and a center locked pully my only guess now I maybe the chassis could be tweeked if any one can please help me I would greatly appreciate it its driving me crazy!!!
#3240
That happend to me before when I first drove the Cyclone. I found out "my" problem. It was the tires. I had a brand new set of Rides 36's. Couldn't figure out what was going on. Everything checks out fine. My friend told me to change the tires and then it was hooked up! I ended up using my used set of Sorex 36's. Some times it could be as simple as that. The center line on the new tire sets throws the car off a little.
You can also check your droop and ride height. What oil in your shocks? Are they all evenly filled? Springs being to soft? Racing mod or stock?
