Team Associated TC6 Thread
#6781
Tire rubbing Levanen TC6.1!
#6782
On the tire rubbing, I noticed this a while back and posted about this although nobody seemed to have much input. I did notice that some wheels have a smaller diameter than others so it can be worse. It is especially bad under suspension compression. I have been considering going back to tc6 arms in the rear at least, which actually should aid with traction as they are a bit shorter.
#6784
#6785
It's not from the wrong offset.
I tested today with some Sweep OG , and with Solaris wheels as well. I had really bad rubbing from the wheel flexing in the front
Given it was about 95 degrees F and the track was huge (18.5-19.0 second laps with a 4.0 turn motor) with medium high grip, so this made it worse, but I did have to trim the front arms quite a bit. Not that much of a hassle, but it is something to watch for when running faster motors.
#6786
Hoping to see some of you out here in California for the Reedy. Today was a warm-up race. A great showing for Associated, with several team drivers attending.
This is only the 3rd time out with the 6.1 and I love this car! A big thanks is due for The Albano's - Joe, and Eric - Helping me get the car working well. Support like this at a local track is why I switched to Associated.
IMG_9734 (2) by 51 wheels, on Flickr
#6787
Hi,
I'm actually using offset arm mount at the front of the car. If I use the standard one, but with 1.5mm shim, I will have move steering at corner entry?
#6788
Never raced on concrete, but if the grip levels are medium I'd think any of the medium-grip Asphalt setups will be fine. Try one of Andrew Abbotts off the Associated site, or Olly Jefferies off the CML site.
#6791
Depends how hard you hit the wall
I actually have some hubs, suspension parts and maintenance parts like shocks as spare parts.
Oh yeah. Take some spool outdrives as a spare, they brake first on a crash
#6793
Yes arm mount shims, FWD(forward) RWD(rearward) for that end of the car, you would run the same in the front forward and front rearward, and possibly different ones in FWD and RWD in the rear to adjust rear toe, along with a combination of offset and standard arm mounts.
I use these for the shims, Associated #3617
http://www.amainhobbies.com/product_...-Bulkhead-Shim
Hopefully this is a more helpful answer than "RTFM"
#6795
The car is actually pretty solid and durable. The things I did break were from stupid hits that deserved something breaking. I pretty much did all of the damage on my first day out. I didn't break a single thing on the 2nd race day. Less hitting the boards, and when I did it was less severe hits.
So far I think this is a great little car.
