Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 10-09-2017, 12:07 PM
  #11566
EbbTide's Avatar
Trader Rating: 39 (100%+)
Originally Posted by trevor1030
Would you recommend that one instead?
can the original body fit on the chasis? Or am i looking at it wrong, seems like it widens it so not sure if bodys can fit!
From Cain's reported performance using that Exotek Pro 17 chassis, I would definitely recommend it over any of the current chassis upgrades (it's obviously not the most cost effective of the bunch though).
And the original body should fit fine or else Exotek would have mentioned it in their product description page. They are very good about adding the necessary details.
EbbTide is offline
Old 10-09-2017, 12:10 PM
  #11567
If you think it is better then the schelle stretched i wil give that one a go! I just dont want to have to trim or do much more cutting to my bodies!
trevor1030 is offline
Old 10-09-2017, 12:12 PM
  #11568
EbbTide's Avatar
You really shouldn't need to do any extra trimming mate I would however recommend a 3rd party body because I genuinely hated using the stock body because of its assembly lol.
EbbTide is offline
Old 10-09-2017, 12:13 PM
  #11569
Cain's Avatar
Trader Rating: 294 (100%+)
If you want one, I have one as part of an upgrade package for sale (exotek chassis NIB, the carbon chassis parts, NIB ceramic bearings, NIB Lunsford turnbuckles) available. Search my name for it on the for sale section. selling only as my youngeest who is getting the D413 her sister has doesn't need it for what she is going to do lol
EbbTide likes this.
Cain is offline
Old 10-09-2017, 12:14 PM
  #11570
i do have, proline bodies, but i was more concerned with finding a chasis protector that fits, cool thing with schelle is that it comes with one. Anyone have any recommendations?
Old 10-09-2017, 12:16 PM
  #11571
EbbTide's Avatar
I just buy the cheap clear chassis protectors from jconcepts that come in a pack of two. Then just stick it on your chassis and use an exacto knife to cut around the edges.
EbbTide is offline
Old 10-09-2017, 12:20 PM
  #11572
Cain's Avatar
for protector I use the same as Ebbtide or I use some 20mil PVC tape that is like $5 for a big role. Its pretty thick. Just heat it up when you apply it so it sticks well.
Cain is offline
Old 10-09-2017, 04:29 PM
  #11573
anyone have a Avid floating servo mount they would want to part with? Order a few parts like Exotek diff cap, 10 degree caster hubs, Schelle racing stretch chasis, aluminum wing mount set and 72t spur gear and mounting plate!
Looking forward to adding these to my HB D413, i wish i could find the Avid aluminum chasis and the floating servo but i cant find any =(
The Avid floating mount is not a direct bolt on to the Schelle chassis. You will have to drill some holes in the chassis to make that mount work with that chassis.
urnotevenwrg2 is offline
Old 10-10-2017, 09:40 AM
  #11574
90sRacer's Avatar
Default Top Brace and other tuning question
So this weekend I had a pretty subpar performance with my buggy. The track layout had changed, and I had a hard time getting my car hooked up. While waiting for the first race to begin, a fellow racer with a B64D had commented that my car looked pretty “stubby” compared to his. I agree, the wheelbase is certainly a little smaller on mine. There was a washboard section on the track and the buggy was very unstable on this section. I decided to move the spacers on the rear arms all the way to the front to try and extend the wheel base a little bit and gain stability. Not sure if that helped or not, but I think it did as my lap times improved, but I don’t know if I can simply attribute that to more laps on the new layout. It had me thinking though, the Exotec chassis which is longer, does not always use the top decks. My buggy has the original factory length AVID aluminum chassis and I am using the top decks. I’m curious if I remove the top decks if I will gain a little bit more and drivability with the buggy. Has anyone removd the top decks? I know this isn’t something you’d want to do with the stock chassis, but with the aluminum chassis it may be ok?
Also, I was comparing my buggy with that B64D and also noticed the droop on the front of my car was extremely greater than his. I’ve never messed with the droop, and wondering what feedback fellow D413 drivers can provide in regards to shortening the droop. Many thanks for your help.
90sRacer is offline
Old 10-11-2017, 10:00 AM
  #11575
anyone have a setup for a mid to high bite indoor clay track i havent raced 1/10 4wd car in like 2 yrs?
nolimit1984 is offline
Old 10-11-2017, 10:29 AM
  #11576
Hot Bodies D4'13 - Ty Tessmann - Gunsmoke Classic - IERC - 14-16.11.2014
THis is a good one.
2004hdfxsti is offline
Old 10-12-2017, 06:55 AM
  #11577
jasburrito's Avatar
I just changed all my camber links to the positions shown in setup. I used 2 Allen’s to hold ball cups so they would not try to pop off and or loosen fit. Maybe this can help others. Cheers.
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-e322577c-1714-47e7-8496-42bd6f53b9ec.jpg
stanleyw808 likes this.
jasburrito is offline
Old 10-16-2017, 08:06 AM
  #11578
boudin4evr's Avatar
Trader Rating: 18 (100%+)
I want to sale my SERIOUSLY ONLY 1 race day D413, it has custom never cut body, clay dirt webs, extra parts, exotek goodies throughout, aluminum caps, manual, box, etc.
what is a good asking price so that I can post it?
also a 1 day old tekin redline gen 2 6.5 option to leave it in buggy
thanks again
boudin4evr is offline
Old 10-16-2017, 09:29 AM
  #11579
mustangkillaz's Avatar
thanks again
Damn, 1 day old, did it suck that much that you're dumping it? Just curious.
mustangkillaz is offline
Old 10-16-2017, 09:37 AM
  #11580
boudin4evr's Avatar
built it ALL NEW ELECTRICS
raced it 1 day
very sweet car, run more outdoors 1/8
Im a tekno driver so...
