Team Associated TC6 Thread >
Like Tree20Likes
Old 05-14-2012, 06:50 PM
  #6751
NateRug's Avatar
Originally Posted by jhautz
Has anyone tried to mount a VTA body on a TC6? I picked up a used one to run in VTA but the front body posts are way to short to fit the VTA body. Is there something longer that will fit? Im sure I can piece something together, but I just thought Id ask to see if there is something that is an easy bolt on solution for a taller front body post. Its hard to tell how long the posts are looking at pictures n the internet and Im sure someone has already solved this.
Thanks in advance.
HPI #6507 Universal Body Post Set 4-40/3mm also work well
NateRug is offline
Old 05-14-2012, 07:58 PM
  #6752
chevtech23's Avatar
I use the associated bulkhead shims under the body post to raise it up a bit.
Thanks in advance.
chevtech23 is offline
Old 05-14-2012, 08:07 PM
  #6753
jhautz's Avatar
Trader Rating: 86 (100%+)
Perfect. Thanks Guys. I ordered set of the HPI posts. They looked the longest and I can always cut them down. The AE posts looked to only be 1 hole longer than the stock posts and I wasn't sure that was enough.
jhautz is offline
Old 05-14-2012, 09:34 PM
  #6754
KH
Originally Posted by Rick Hohwart
Can someone give me a hand? I open this link but it's just a blank setup sheet for me. There's only a cpl on the associated site that I can see...the rest are blank.
KH is offline
Old 05-14-2012, 10:06 PM
  #6755
CristianTabush's Avatar
Trader Rating: 13 (100%+)
Try using ie or firefox to view, these sheets don't pull up on ipod/ipad/iphones.
CristianTabush is offline
Old 05-14-2012, 10:08 PM
  #6756
midse's Avatar
Default TC6.1 Parts
Can anyone help me pls. I want to know the comprehensive list of upgraded parts the tc6.1 has over the tc6 - The petitrc list and the Team Ass. sites don't list the gear diff and outdrives etc. Also did the 3 hole vertical rear diff top brace come out with the tc6.1 or is it a factory aftermarket item?
midse is offline
Old 05-14-2012, 10:44 PM
  #6757
Here is parts list for upgrade to TC6.1 as posted by Associated:
http://www.teamassociated.com/news/a..._TC6.1_FT_Kit/
zzztech is offline
Old 05-14-2012, 11:18 PM
  #6758
arn671's Avatar
Trader Rating: 17 (100%+)
Default 88mm chassis
Noticed the stock chassis was narrowed to 88mm. 4mm on each side shaved off? To reduce chassis rub? By Narrowing it does the chassis become more flexible? Thanks
arn671 is offline
Old 05-14-2012, 11:36 PM
  #6759
Yeah would have more flex. Super narrow chassis seems to be fashionable these days.
zzztech is offline
Old 05-15-2012, 12:50 AM
  #6760
narrow chassis is not easy to touch the ground when cornering
edwardcs is offline
Old 05-15-2012, 01:00 AM
  #6761
midse's Avatar
Default tc6 vs tc6.1
Thanks but as I already mentioned in my above post - the Associated site doesn't list all the upgraded parts such as the gear diff
The tc6.1 kit comes with these parts in the box - tc6.1 owners please add other parts it comes with
784695 313569 #31356 TC6.1 Front Arms $7.99 January 2012
784695 313576 #31357 TC6.1 Rear Arms $7.99 January 2012
784695 313583 #31358 TC6.1 Caster Blocks $7.99 January 2012
784695 313590 #31359 TC6.1 Rear Hub Carriers $6.99 January 2012
784695 313606 #31360 TC6.1 Steering Block, 1pr. $5.99 January 2012
784695 313613 #31361 TC6.1 Offset Arm Mounts $8.99 January 2012
784695 313620 #31362 TC6.1 Anti-roll Bar Set $27.99 January 2012
784695 313637 #31363 TC6.1 Anti-roll Bar Tube $8.99 January 2012
784695 313644 #31364 TC6.1 Anti-roll Bar Wire, qty 4 $9.99 January 2012
784695 313651 #31365 TC6.1 Anti-roll Bar Mount, qty 4 $3.99 January 2012
784695 313668 #31366 TC6.1 CVA Kit $29.99 January 2012
784695 313675 #31367 TC6.1 CVA Rebuild Kit $6.99 January 2012
784695 313682 #31368 TC6.1 CVA Bone, qty 2 $14.99 January 2012
784695 313699 #31369 TC6.1 CVA Axle, qty 2 $9.99 January 2012
784695 313705 #31370 TC6.1 Axle Crush Tube, qty 4 $3.99 January 2012
Rear Gear Diff
Rear outdrives to suit rear diff
Front solid spool
Front outdrives to suit front spool
midse is offline
Old 05-15-2012, 02:34 AM
  #6762
Big Features's Avatar
The TC6 does come with a gear diff and solid front axle. The 3hole bearing caps are a new FT part and are not a running change to the kit. As far as chassis go, the 6.1 still uses the original chassis.
Big Features is offline
Old 05-15-2012, 07:54 AM
  #6763
Rick Hohwart's Avatar
My understanding is that this was done to prevent the chassis from dragging, not to increase flex (although it will slightly).
Rick Hohwart is offline
Old 05-15-2012, 08:39 AM
  #6764
Mike Haynes's Avatar
Rick, correct. Between riding curbs and a fast sweeper my car was dragging a lot, and sometimes would catch and spin out, the narrower chassis reduced that. It does flex a bit more so i went back to a regular upper deck (instead of one cutout (front and back) as we usually run. I must thank Dawson and FJ for their help (its always nice to hear what my car does wrong) after a few weeks of heavy testing i was very happy with the car
Mike Haynes is offline
Old 05-15-2012, 12:43 PM
  #6765
jhautz's Avatar
What were you cutting on the upper deck?
jhautz is offline
