Help me remove stripped screws (not as easy as you may think)
#16
The best method I've seen (without a dremel) is using a AUTOMATIC pin hole punch.
It's a heavy spring loaded pin punch and you work around the screw using it to free it.
http://buy1.snapon.com/catalog/item....re&dir=catalog
If that doesn't work, its a dremel, drill or dissassembly.
#17
Its not just my steering screw, its every screw on the upper steering plate. I'll try drilling it.
#18
watch?v=7v5jhJK3tgg&feature=related
( youtube.com....can't post links yet )
This is how I remove my stripped countersunks ( loctite or no loctite )
#20
a drill bit worked great for me when a clutchbell "dome"screw got rounded out. i used a bit slightly smaller than the screw, and every single piece of the screw came out with the shavings. works perfectly.
