Triton DC computerized charger >
Old 07-17-2003, 04:30 PM
Trader Rating: 32 (100%+)
Default Triton DC computerized charger
Like New $89.00
gulio is offline
Old 07-29-2003, 08:07 PM
pic
gulio is offline
Old 08-05-2003, 06:20 PM
ttt
gulio is offline
Old 08-05-2003, 08:45 PM
ill go 65
biged is offline
Old 08-16-2003, 12:54 AM
sorry, they are all going @ $95.00
but one more left
gulio is offline
Old 10-14-2003, 12:17 PM
Default one more
I'm selling the one I've been using , it is like new, works perfectly.
same price $89.00 plus $5.00 shipping
gulio is offline
Old 10-22-2003, 07:35 PM
ttt
gulio is offline
Old 10-22-2003, 09:21 PM
Trader Rating: 12 (100%+)
is that a AC/DC charger?? if not does it come with a power supply?? also whatz the lowest you will take shipped???let me know I might be interested...
chrisnitro is offline
Old 10-22-2003, 11:30 PM
It is dc only and the 3 amp powersupply (new) are 7.99 each if you want any. The lowest for the charger shipped is $95.00
gulio is offline
Old 10-23-2003, 09:27 AM
pcnutz's Avatar
Trader Rating: 18 (100%+)
the triton requires a 14 amp 12v power supply a 3amp power supply will not work on about 3/4 of the charge and discarge settings
pcnutz is offline
Old 10-23-2003, 01:55 PM
The Triton requires 90 watts of power to do up to full capacity.
That is 5 amps at 18 volts. My little 3amp ps gives 36 watts each, enough to do a 6 cell battery (9volts) at about 4 amps. It will also do most all rx and tx and small jobs.
I always just use 3 amps and if I need more I plug in another and if I need more just plug in another for a total of 9 amps at 12 volts. This is 108 watts of power, more than enough to max out the capacity of the triton.
I was merely offering to give a little cheap but new 3 amps supply along with it as it doesn't give any voltage errors like some other power supplies do. It will also do any of the settings that require 36 watts or less. I also offer the temp probes new for $9.99
gulio is offline
Old 10-23-2003, 02:11 PM
wow, seems to complicated, i'll pass....
Old 10-28-2003, 04:00 PM
ttt
gulio is offline
