Novarossi engines thread
#496
Originally posted by BrainTeased
thanks Ziggy i need one of those digital verniers! no way i can get that 0.018 figure on a scale vernier.
but apart from that do you think im putting too many shims in? after reading that headshim thread im pretty sure that the VERY VERY thin shim is the 0.08 shim and the other 2 silver novarossi shims are 0.010 so maybe i have 0.028 mm shimmed installed? so basically does it sound normal to have 0.028mm shimmed on 2-3 litred old novarossi engine? maybe it was just my bad tuning skills that made it flame out the first week. (trying to tune the bottom end lean first)
The very thin shim must be the 0.005"shim as they make that one
Cheers
#497
BT,
Here's the nominal measurements of the standard Nova shims.
Silver: 0.3mm - or about 0.012 inch.
Copper: 0.1mm - or about 0.004 inch.
1mm is equal to about 0.040 inch - it's actually 0.039 . . . something, but close enough for this purpose.
Yes, you'll need a digital caliper.
#498
Where can i get a barrel carb for an NSR S3? I need 2!
Cheers
Cheers
#500
Originally posted by Taylor-Racing
BT,
BT,
thanks for clearing up one thing with the mm's and the inches
how do novarossi engines come out in terms of shims installed when the engine is new?
#501
No problem.
I think our NSR came with one silver shim, but if I recall, the older Nova's came with a silver and a copper fitted as stock. I could be wrong here.
#503
I t is said that the piston of Novarossi new version .12 engine is made of ceramic alloy. I s it true?
And which piston is better?
ceramic?
CNC aluminium ?
microcast aluminium?
ceramic?
CNC aluminium ?
#504
I had purchased a IDM 12 3 port a couple of months ago and had major problems with it since day one. No matter what carb setting it would alternately overheat or stall or run poorly and would destroy plugs at an increadible rate. Well yesterday i checked the rod and it was quiet worn so I figured it was detonating from conrod bushing play. Pulled everything apart and to my shock found that NO shims had been installed from the factory! I was effectively .4mm less head clearance than factory . The engine is toast now... p/s is fried/ head button is pitted to hell....crank and bearings are ok though. What should I do? I was going to go to the store that i bought it at and also mail Muegenseiki japan. Do you think I have a claim or not?
sorry for the novel.
#505
#507
carb question
Hiya,
Could anyone tell me if it possible to replace a carbs from a NSR 12 3 ports with a carb from a 15 size engine from the same make ? Will any mod be needed ?
#508
RS12 T5S1
Hey Guys,
Can anyone tell me what the carb settings are for the RS12 T5S1
and can anyone suggest some glow plugs (turbo Plugs)
thanks
thanks
#509
Re: RS12 T5S1
Originally posted by jferg10472
Hey Guys,
thanks
Hey Guys,
thanks
5 turns out High speed screw
3 turns out low speed screw
good to get it started.
or you can try
2.5 turns out low speed screw
and high speed screw sitting flush with the highspeed screw body.
