Buying a house, it all must go! >
Old 06-14-2007, 02:34 PM
  #16
Dude......I've been trying to get those programers off you for months. WTF!
Stampede is offline
Old 06-14-2007, 03:27 PM
  #17
Default novak 4.5
Originally Posted by Greg Anthony
I find it slightly ironic, but in order to afford a house to put all this great stuff in, I have to sell all the great stuff to start with!
e-mail me at [email protected] for all inquiries/offers/questions.
Don't forget to check back often, I have MANY more coming soon!
CARS
***Speedmerchant Rev 4.5. This was my 19T car that was built for ROAR Indoor Nats at CEFX and has only been used at NatsThis car has the BEST of everything. Has Bruce's lowered front steering blocks, IRS lightened diff rings, all Aluminum screws, full set of IRS ride heigth adjusters, Lunsford ti turn buckles, mostly part losi ti ball studs, and a full set of 8-32 Lunsford Ti screws for the front suspension. It currently is sitting in my hobby room AS IT CAME OFF THE TRACK from the the third A-Main at Nats (tires included). $230
(*also available as a DIFFERENT package, the car, complete with the 19T motor, PRS pinion, Novak GTX (new for NATS ONLY!), KO 949ics servo, and transponder. The only thing I'm keeping is the body, but can include my practice body if your interested. If you want the WHOLE CAR/electronics, e-mail medirectly for a price!!!)
***Speedmerchant Rev 4.5. This was my Modified car that was built about a month before the ROAR Indoor Nats at CEFX. Qualified in the top of the b-main. This car has the BEST of everything. Has Bruce's lowered front steering blocks, all Aluminum screws, full set of IRS ride heigth adjusters, Lunsford ti turn buckles, mostly part losi ti ball studs, and a full set of 8-32 Lunsford Ti screws for the front suspension. The car is currently also is sitting in my hobby room AS IT CAME OFF THE TRACK from the the third A-Main at Nats (tires included). $215
(*also available as a DIFFERENT package, the car, complete with the Novak GTB speedo, the 6.5 motor w/ sintered rotor, PRS pininion, KO 949ics servo, and transponder. The only thing I'm keeping is the body, but can include my practice body if your interested. If you want the WHOLE CAR/electronics, e-mail me directly for a price!!!!!)
** If someone buys either one of the above cars, I will offer them All my Jaco's fro Nat's as well as EVERY JACO I HAVE for 1/12th whick includes at least 10 full sets that are either new in the box, or trued and not used, not to meantion the PILES of 1 and 2 run tires for Nats and the week of practice before Nats.
I also have numerous spare parts I have for the speedmerchant, MANY MANY front end parts, Bruces new side springs, other SM parts, center spring sets, many many more, hoot me an e-mail if your interested or have something special to request, I have WAY too much 1/12th stuff to list everything, I can't type that fast and it'll be way too much to read!
BRP 1/18th Car $60
-Complete kit
-Custom Painted Saleen body
-Practice Red Monte SS body
-2 motors tuned by Bud himself
-Orange/hard front tires
-Ball diff
-6 HPI/slot car pinions
Tamiya F201 $125
-original kit box
-lightweight diff’s front and rear
-lightweight shafts and gears
-Optional shock piston’s
-Universals on the front
-Soft Ride tires
-Aluminum motor mount
-High speed gear set
-Black motor
-Aluminum motor guard
-New rear wing
Tires
-Tamiya A-Types
-Kit set
-Hard “Bridgestone’s”
-NIP SP-936 rims
Parts
-2 black motor used
1 used
1 not broken in yet
-NIP OP-513 Turnbuckles
-Spare plastic parts
-Metal diff ½’s
-2 sets of diff bevel gears
-stock gear set
-1pr stock front dog bones
-stock shafts
-optional spring set
-graphite front plate
-clear stock front end plate
-“Practice” body
-Lots of stickers
Electronics
2 - 949ics's in them, both were new for Cleveland, $65 each
Novak GTX wired up in it (new for Nats) $125
Novak GTB (with custom heatsink plate) wired up for a 1/12th, and the 6.5 w/ sintered rotor and stock rotor. $230
Novak 4.5 w/ sintered rotor and stock rotor I'll add with the above for another $65
4 Corally MMS-3’s
-3 with KO Type One Nickel heat sinks $110ea
-1 – w/o heatsink $95
KO VFS-1 Multi Setting Handheld Adapter Set for VFS-1 Series $45
KO ICS PC Interface for Digital Servo and VFS-1 Set Series $45
KO PDS-2123FET 7.2V Digital Servo $65
-no tabs
-With extra bottom ½ of case – new
Airtronics 94357 Hi-Speed Servo’s $60ea
-with one side of tabs
2 JR Z-3550 hi-speed servo’s $20ea
-w/o tabs
13A cosel power supply $40
Turbo 35 GFX just a year old - $300
55amp Iota Power Supply (new in Jan, build datye of 11/22/06) This is the company that makes Rivergate (they just lick and stick their tag on it) - $175
30 Amp Rivergate powersupply, build date of 6/29/04 - $130
New Novak Tray (new used only at Indoor NATS) - $60
Much-More Blue 12V Cooling Fan Stand New Never Used $30
Fantom Dyno $250
-With Aluminum
-With Original Software
-With EverStart Battery P/N U1-7 230 Cold Cranking Amps
-With EverStart 1Amp Manual Trickle Charger Model WM-1
TC rubber tires
1 set 1 run RP30GL $25
1 set 2 runs on carpet CS-22GL $20
CS-27GL
1 set 1 run at Worlds in Florida $20
3 set 2 runs at Worlds in Florida $15 per set
8 sets of tires $10 per set
Eagle Racing
2pr Low Profile 25R Belted Super Narrows and 1 pr Rims $10
New In Package
1 set New In Package RP30GL $35
1 set New In Package CS-22GL $25
4pr New in Package 28R $12ea
5pr New in Package HPI Red Inserts $3.00ea
1pr New in Package 26mm Velocity TC Rims $3.00
1pr New in Package 26mm 10-spoke TC Rims $3.00
1 set of 4 XRAY rims $7.00
3 rims from Losi XXX-S kit $3.00
Sorex
20R
1 set of 2 run tires on 24mm Yokomo Hard rims with HPI red inserts $8.00
24R
1 set of used tires on 24mm Velocity rims with HPI red inserts $8.00
28R
32R
3 set of used tires on 26mm Velocity rims with HPI red inserts $10.00ea
1pr of used tires on 24mm Velocity rims with HPI red inserts $5.00
36R
1 set of 3 run tires on 26mm Velocity rims with HPI red inserts $15.00
1 set of used tires on 24mm Velocity rims with HPI red inserts $10.00
2 set of used tires on 26mm Velocity rims with HPI red inserts $10.00ea
40R
1set used with HPI blue inserts with Yokomo Hard rims $10.00
Foam Tires
1/12th Tires
Parma
Fronts
Magenta – 2pr NIP, 1.642, 1.665, 1.643, 1.666, 1.652, 1.671, 1.611, 1.627, 1.615, 1.668, 1.658, 1.662, 1.654, (2) 1.652, 1.665, 1.668, 1.6761.645, (2) 1.683, 1.639, 1.624, 1.655, 1.660, 1,669
Black – 2pr NIP
Rears
Grey – 1.720, 1.695
Pink – 1pr NIP, 1.783, 1.782, 1.775, 1.712, 1.725, 1.713, 1.756, (2) 1.719, 1.740, 1.725, 1.722, 1.730, 1.750, 1.723, 1.777
Black – 1pr NIP, 1.783, (2), 1.781, (3) 1.778,
Magenta – 1.750, 1.752, (2)1.740,
CRC
Fronts
Grey – (4) new dish cone rims (not hi-rollers)
TRC Grey Ring spec tires
Fronts
Green – 2.215, 2.125, 2.210, 2.095, 2.165
Blue –2.145, 2.125
Orange – 2.215, 2.200
Rears
Green – 2.073, 2.095, 2.205
Blue – 2.178, 2.265, 2 new never trued 2.265
Jaco 1/10th Tires
Front
Purple – 2.196, 2.185
Green – 2.172, 2.185
Black – (2)2.190, (2)2.195
Rears
Black – (2) 2.195
White – 2.165, 2.180, 2.185, (3) 2.195
Parma TC Tires
Cyan – 2.225, (2) 2.185,
Magenta – 2.277, 2.272, 1.191, 2.197, 2.225, 2.298, 2.195
TRC Yellow TC Tires (28mm)
Cyan – (2) 2.207, (2) 2.205, 2.203, 2.200
Magenta – 2.200, 2.198, 2.195, (2)2.193, 2.192,
MISC
Set of Integy Blue Anodized Touring Car Set-Up Wheels $15
New Large Hudy Set-up board $30
Integy Setup Station w/ Case $65
-comes with carrying case
-Both Metric and standard thumb screws
Brand new never used CRC 6-Pack chassis $30
NIP IRS4005 Rug Rat Dampener Tube set $10
***Buyer to pay shipping costs, Inquire about shipping…****
Please send all inquiries to [email protected] ONLY!!!! With the item description in the subject of the e-mail.
Pictures available for all items, check back often for updates.
Thanks for looking!
Greg
P.S. Coming soon, all my 4200's, TC brushed mod motors, 1/12th brushed mod motors, tons of stock/19t's, all my off road stuff (cars xx-4, t3, t4 and tires for all plus some for a b3), and MANY MORE!!!!!!!
would like to know how much for the novak 4.5? my em is [email protected] thanks
jts5555 is offline
Old 06-14-2007, 04:45 PM
  #18
Originally Posted by viper55
hey, could i get some pics of the integy set up station?
thanks
- viper55
e-mail me and I can send you some...
Greg Anthony is offline
Old 06-14-2007, 04:47 PM
  #19
e-mail me then! as of when I list had a couple of these things posted, I had replied to all e-mail's I have....
Old 06-14-2007, 04:56 PM
  #20
roadkill's Avatar
Trader Rating: 152 (100%+)
Default mail
you have an e mail about foam tires
roadkill is offline
Old 06-14-2007, 04:58 PM
  #21
Roadkill, replied to!
Old 06-14-2007, 06:17 PM
  #22
many,many more things added!!!!!
Old 06-14-2007, 07:02 PM
  #23
Very intrested in KO PDS-2123FET !!! ill give you 50 right now pm me!!!
Refujiado is offline
Old 06-14-2007, 07:29 PM
  #24
SOLD! e-mail me!
Old 06-14-2007, 07:37 PM
  #25
roadkill's Avatar
NEED PP ADDRESS
roadkill is offline
Old 06-14-2007, 07:55 PM
  #26
chedda bob's Avatar
Location: Where the ego's are so big, people's heads can't fit in the door
Trader Rating: 149 (100%+)
e-mailed about some stuff and i am local. please give me a call tomorrow
# in e-mail
chedda bob is offline
Old 06-14-2007, 08:56 PM
  #27
roadkill's Avatar
payment sent for foams
roadkill is offline
Old 06-14-2007, 09:19 PM
  #28
slufoot78's Avatar
Trader Rating: 60 (100%+)
You have Mail
slufoot78 is offline
Old 06-15-2007, 02:28 AM
  #29
mbunker's Avatar
Trader Rating: 32 (100%+)
you have mail about the large setup board.
mbunker is offline
Old 06-15-2007, 04:53 PM
  #30
chedda bob's Avatar
would like to pick stuff up tonight?
