Tekin RS ESC sensored
#7006
Wow all these power cap discussions when i have a problem! what are the chances Got a race meet tomorrow and my cap has snapped off from the base. The only thing i have that could possibly use is a cap from a KO VFS-1 old brushed speedie. Is it advisable to run it while i chase down a replacement? Quick response would be awesome, really should be in bed now.
I have a RS pro running 17.5 Brushless.
Thanks in advance,
Steve
P.S the cap i have is at the bottom of the page
http://www.kopropo.com/america/index...=82&Itemid=140
Thanks in advance,
Steve
#7008
I'd read the instructions. They're on the website as well.
http://www.teamtekin.com/manuals/RSManual.pdf
#7009
Happy
Hello people,
Have to say i`m very happy with my rs pro and a redline 13.5 motor,
been driving nitro for the last years but now with brushless is here its my future.
There is 1 thing i would like to know, maybe you guys cann help,
I`m trying to open my 13.5 redline motor but the allen wrench doesn`t fit.
2mm is to small and 2.5mm is too big ??????????
Are the scres in the motor englisch size???????
If yes, what is the dimension i have to buy?
Kind regards,
Roy B.
Kind regards,
Roy B.
#7010
3/32nds...
#7011
Now that the v200 software has been out for a bit, I have some questions regarding the appropriate use (rules of the road) of its features with my system as I wait for my Redline 17.5 and HotWire to arrive.
1. To create a frame of reference, I would like to use the IIC layout from this year. As I have a carpet track (OCRC) near me, to help make this conversation more relevant. The point of my questions are to understand why would I want increase or decrease my motor timing either mechanically or in the software or the gearing based on track size and layout.
What I am running:
Class: Amateur
Car: Cyclone S
Speed Controller: RS
Motor: Redline 17.5
Motor timing: 10 degrees (on the can)
Gearing: 4.4 FDR
Batteries: Orion 3600
Radio: M11 with Spektrum
Tires: Jaco blue's (spec tire)
Given the track layout and size:
2. Is my gearing correct? If not what should I be looking at for gearing?
3. Is my motor timing correct? If not what would be recommended and why?
4. What timing boost and why?
5. What turbo boost and why?
6. There was a change to the firmware on the speed controller that Randy did to allow users to have a delay set to .3 instead of the .5 that is standard. Why was this change needed?
7. How would a 10 percent change in track size either smaller or bigger affect
any of my settings and why?
I appreciate that anyone who responds will have a personal point of view on this and no one will be absolutely correct as there are many more factors such as driving style, car setup, and actual track conditions/surface that play important roles on all of this that you cannot see based on my description. What I am hoping for is to gain a better understanding of the how and why things are done to recognize what I may see and where/how I can adapt to it useing the RS and HotWire.
Thank you in advance for any assistance you can provide.
What I am running:
Class: Amateur
Car: Cyclone S
Motor: Redline 17.5
Gearing: 4.4 FDR
#7012
#7014
Randy, quick question about the turbo delay.
When we set it at 0.5sec, does the turbo activate 0.5 seconds into full throttle regardless of motor rpm/load? Or does it wait for the load/rpm to reach a certain level before activating? Even if its longer than 0.5 sec?..
#7016
Turbo kicks in according to the timing delay; load/rpm has no effect on the turbo kick in and this is why setting the timing delay is very important and can be very different from track to track.
#7017
With wiring the RS for Brushed motors, is there any difference between the two methods indicated on the manual. I'd prefer to wire it to the "forward and reverse" way as it will be easier to switch between brushless and brushed motors as I wish. I don't like the idea of taping into the positive wire of the speedy, and leaving it exposed when not using Brushed motors. I will be only using it in Forward mode only, is this okay. Also as far as settings go what can be adjusted on the speedy for Brushed motors. This is for 540 motor by the way.
Your help is appreciated.
#7018
Put me down for 2 more Tekin converts with an assist going to Randy My boy Art was more than impressed with Randy at the iic and the local BOR will be switching as well. Now if I can pull my head from you know where and win a race everything would be great Tekin soon to be region 12 spec 13.5 champ
#7019
I'm just wondering if is that right or not
with fixed timing 13.5T motor
25 timing boost has more Top speed but Less torque than 15-20 timing boost is that right?
Local Carpet Track is really small and technical,tight 6.5 FDR feels ok...
On the other hand Randy Says The target timing should be 30...
I'm a bit confused...
Also What's the bes throttle profile for 13.5T Stock Racing? Some of my friends thinks the most aggressive throttle profile suits the Stock Racing is that Right?
Thanx in advance
Thanx in advance
#7020
Along this same line, would I notice a discernible difference between the RS and RS Pro in 10.5 1/12 scale? What about with an 8.5 in an RC10B4? Aside from the Redline motors, are there any others that would be recommended to use? (just in case I can't get a hold of the pair together, this stuff is super pricey in Germany...) Thanks!!!
