Kyosho V-ONE RRR EVO 2 >
Old 02-11-2011, 07:07 PM
  #2566
Originally Posted by DuVulcha
OK quick question. I stepped up from a TC3 to a V ONE RRR. Got it all together, broke in motor (7 tanks) and finally got ready to run it a bit. take it pretty calmly through some corners and hit the straight and gun it. The motors signature did not reflect the cars actual acceleration and when I breaked at end then gassed it to get out of turn motor wailed but car didnt push. I couple of throttle pulls and the clutch finally engaged again. I did this continually coming off high RPMs. Could this be my clutch spring was too tight? any help would be greatly appreciated.
What happened when you pulled the throttle exactly?
Did it scream and do nothing, or burble its way up and then start to engage?
Maybe your clutch spring may be too tight, but if its screaming its ass off and going nowhere, and then going every other time, I would say its the one-way bearing in the first gear slipping.
DJ_Shakespear is offline
Old 02-11-2011, 07:22 PM
  #2567
Trader Rating: 13 (100%+)
Well the first time you gun it its like a rocket down the straight. But then you gun it and its a lot of engine wailing but no power to the wheels. It comes and goes sporatically. I have two of them so my plan tomorrow I guess is loosen the clutch and if that doesnt work rob the one way off my back up until I get another one in.
DuVulcha is offline
Old 02-11-2011, 09:49 PM
  #2568
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Default explanation
a little different version that time. the one way you can clean it out with nitro spray and then re oil it with a little marvins mystery oil don't ever blown the one way with air hose just let it dry it then re oil
Speedypeterb is offline
Old 02-12-2011, 07:14 AM
  #2569
So its good coming down the straight, you back off at the end and gun it after the next corner - it screams but goes nowhere and then all of a sudden its like you drop the clutch?
If so, I would definitely either replace the one way bearing or give it a good clean out and re-oil it with quality one-way oil.
But only replace it if you are absolutely sure that the rear belt pulley is not loose - ive done that before, no power and check ed the rear small pulley, sure enough the screw was loose.
If everything is nice and tight, then Im almost certain its just the one-way bearing giving out on you.
Old 02-18-2011, 12:28 AM
  #2570
MikaR's Avatar
After a nice session of maintenance
MikaR is offline
Old 02-18-2011, 03:18 AM
  #2571
GREGORY!'s Avatar
nice car mika!
GREGORY! is offline
Old 02-18-2011, 03:53 AM
  #2572
MikaR's Avatar
Thanks! You've got a similar?
My running is such limited so I'm keeping this model instead of going to latest and greatest. Plus I have a box of spares that I rarely need, if at all. I installed High Voltage servos and a lipo, though the weight savings are rather subtle. Well at least they're super fast and strong. This baby weights well under 1700 with a transponder in running condition tank empty.
edit: 1696 grams to be exact with transponder and used tires (not worn out). Minimum here is 1700 so it's good news; just a small weight somewhere and we are legal tank empty.
MikaR is offline
Old 02-19-2011, 03:48 AM
  #2573
GREGORY!'s Avatar
here is his brother:
GREGORY! is offline
Old 02-19-2011, 09:26 AM
  #2574
MikaR's Avatar
Nice! How much it weights? What's the pipe? Orion?
MikaR is offline
Old 02-19-2011, 09:42 AM
  #2575
GREGORY!'s Avatar
the pipe is the 2630 novarossi with one orion no conical manifold.
it weights as is in the pic but with body and air filter at 1705gr.
it is a rrr wc.that i turned the upper deck in semi evo-r4 style,with reciever in the left side.the chassis that i use is the sp that i plan to turn it in evo style.
GREGORY! is offline
Old 02-19-2011, 01:00 PM
  #2576
MikaR's Avatar
Cool!
MikaR is offline
Old 02-19-2011, 04:10 PM
  #2577
1evo RRR Driver's Avatar
Trader Rating: 11 (100%+)
I noticed ur upperdeck cut!! kinda like shimos, I did mines the otherday, did u notice any difference in steering or handling?? and do u use the additional holes to mount the front smaller upperdeck piece? I see u drilled the holes but there r no screws in them...........shimo has screws in his!
1evo RRR Driver is offline
Old 02-19-2011, 04:26 PM
  #2578
GREGORY!'s Avatar
the holes are standar in there.now for any diff,
i can't say,because i have not run it yet.tomorrow maybe.
what about you?
GREGORY! is offline
Old 02-19-2011, 05:03 PM
  #2579
what about you?
oh ok I am using the KM racing upperdeck that uses the nt1 tank, my upperdeck doesnt have the additional holes in it, im going to drill them tho, i figure shimo put those extra screws in for a reason!!! I havent ran my car yet either, just did the mod 2days ago, let us kno when u do
Old 02-19-2011, 05:13 PM
  #2580
GREGORY!'s Avatar
some fhotos from yours?
GREGORY! is offline
