Is it the engine or is it the clutch??
#16
Thanks Tony!
I'll pull the diff tonight and check it out. Would you suggest the M2C clutch as well tho? It's not to bad price wise and seems easier to work on then the 3 shoes or just get alum. for the stock setup? Just asking for a second opinion...
Thank you also NitroMan
#17
I did notice that there was a fine line around the bell closest to the flywheel that was discolored but outside of that it looked normal everywhere else, maybe that was from some slag that was caught between the shoe and the bell in that location??
Again, not an expert but because the motor runs great on bottom(still snappy just not as much when its put on the track for the first couple of laps), mid, and top I'm not sure my tune is off on both top and bottom, maybe a little on the bottom so I will adjust it an hour on the rich side and see how that goes. If after a few small adjustments it has not been corrected then I will go back to factory settings and start over.
One more question with the aluminum clutch shoes does everyone typically use the little washers that go on the pins prior to the shoes going on??
Again, thanks everyone for the help!
#18
lol, the AE clutch is a great 3 shoe clutch and I used to love it, but it won't hold a candle to the 4 shoe M2C, especially if you're concerned about $$$. 3 AE aluminum shoes would cost me 30 bucks at the LHS and last one approximately gallon, where 4 M2C shoes will last 4 gallons at 25 bucks, it's a no-brainer if you ask me. The 3 shoe always left slag on my CB, which had to be dremmeled off, not so with the M2C.
#20
Uh.... After reading the post I'm curious. I have an RTR RC8T with the stock .28 motor. I'm noticing my top end really isn't where it needs to be. (not that this motor will be great) I have the stock shoes and springs and the engine seems to rev well but doesn't "pull" on top. Well I had noticed that the bell has heat discoloration. I didn't know if it should or not. (still new) From what I'm hearing I'm assuming my clutch is just slipping. If this is the case what spring/shoe setup should I use? Also, I'm saving for a B5 now. Is there a setup I could use for both?? If not what should I get for when my B5 comes? I'm not too worried about this motor... just want it to last till my B5 gets here hopefully!
On a side note: I was wondering what that weird sound I kept hearing was.... Sounded just like you said... vibrating metal.....
Cheap parts that work well please. Work is slow and I'm having enough bad luck as it is with these things!
#21
Thanks again Nitro... and Quad...
By the way quad... did you get that paragraph long PM I sent you back?
I swear I really think I'm just unlucky... None of my friends are having half the problems I am....
Depending on what the hobby shop has I might go with the M2C setup as I hear good things about it. But if I'm pressed for time I might just get the dynamites... Really depends on the situation I'm in I don't have time to get either in before sunday's race so I don't know what I'll do yet. Will probably depend on what I can find near New Vienna on Sunday.
Any good shops around there Quad? I'm guessing the Fasstrax guy will be up there in Jeffersonville with you this weekend....
#22
