*Servo/PT Problem*
*Servo/PT Problem*
First of all sorry for double posting, I also asked this question in the JRX-S forum, but nobody's on right now, so here we go:
OK I got a little problem.
About two weeks ago, I installed a spektrum in my Helios. Then I installed a Personal Transponder.
->This is what's going on: when the batteries start to dump, the servo movement slows down and when I pull on the throttle, the transponder's LED dimms down and out. When I release the throttle, the LED lights up again.
I suppose the servo needs more current or something, or the GTX can't supply enough for the SPEKTRUM, PT, and 94360Z servo do you think I need a capacitor anywhere? (only capacitor on the car is the big one that came with the GTX)
So, in the beginning, the car drives LIKE A DREAM, then I have this problem, before the end of the race.
I don't have shitty batteries and tried three of my packs. Same problem.
Thanks in advance!
You can see my setup below.
Thanks in advance!
Super Moderator
Thanks in advance!
Thanks in advance!
It sounds like your servo is pulling some major amps and it is dropping the voltage to where it will cut off the servo/pt.
I had the same problem with my spektrum/ko servo...this is what i did to fix it and i have never had a problem since:
I used a servo wire that i soldered to a novak capacitor (just the positive and negative obviously) and plug that servo wire connector - that is only connected to the capacitor - it looks funny, but you don't have to solder a capactor to anything but the connector you use to put in one of the extra connections in the receiver (if your receiver does not have enough plug-ins, just buy a "y-style" adapter - this is what i had to do)
What is happening it sounds like is the voltage/amps gets high enough from the servo, which then pulls the voltage down in the receiver, then the receiver goes into failsafe mode. What a capacitor will do is "store" a little voltage/amps/power so it keeps the power at a nice steady level - and your spektrum has enough power.
As you can tell, I am not electronically oriented, but i can e-mail you a pic of what i did - super easy fix and it should cost you no more than like $5-$7 and take no more than 5-10 minutes
If you look on the spektrum thread here, you will find a little better explanation than the lame layman version i just gave.
mcgoo
mcgoo
Could you send me a pic/pics please? at [email protected]
Thanks a lot!
here is a quote by PitCrew in the spektrum thread:
hope this helps
I used a Novak 4700 mp capacitor and wired it to a servo plug and pluged it into the Batt/Aux slot on the receiver...The Cap solves all the problems. If fact, if I just unplug it, the car goes nuts, then plug it in, everything is smooooth....Dont forget that the receiver itselft draws TWICE as much current as a standard receiver.
should be fine, if it plugs into the reciever, and you have extra servo wire with it, it will be perfect
so I should just get another one of these, right?
as long as it is the 4700 or bigger, from what i have read, alot of folks have tried smaller capacitors, but they were not big enough...i just bought the novak b/c that is what my LHS had available.
mcgoo
mcgoo
that is exactly what mine looks like (besides the novak part) - thanks
Hey,
I went to my LHS today to get the capacitor, but they didn't have any.
So I went to Radioshack and got a 4700mf 35V axial capacitor.
I'll order a novak one online today, but I was just wondering, is it OK to use this 4700 35v capacitor till I get the novak one?(the novak one was 10v i think)
Thanks,
Dan
Thanks,
Dan
