Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 09-10-2013, 10:58 AM
  #4276
bkspeedo's Avatar
Originally Posted by columbia-mk2
The damper is working in symetric mode all the time, and has the same feeling in both directions.
The car is now around 10 months old, the joint looks always wet and rotates with the damper .
Regards!
Contact Oleg via PM he may be able to do something for you.
bkspeedo is offline
Old 09-10-2013, 11:04 AM
  #4277
I saw the Videos, but it was not clear what caused you to slow down after you took the lead. The director hinted that your Car was running on three wheel drive, but it did not seem to have hit hard enogh to cause an outdrive to come loose....
Originally Posted by MDawson
One TQ, 3rd in 17.5 & 2nd in Mod. Not a bad raceday. Thanks Awesomatix, ORCA and Team Larcher!
bertrandsv87 is offline
Old 09-10-2013, 11:08 AM
  #4278
Hebiki's Avatar
Trader Rating: 26 (100%+)
according to facebook..he was FWD only.
Hebiki is offline
Old 09-10-2013, 12:57 PM
  #4279
hanulec's Avatar
Trader Rating: 28 (100%+)
Hello all,
My car started to do wierd things in the middle of the curve, and I have found that one of the dampers is working softer than the other three, and is leaking a bit of oil from the seal.
The outside looks OK.
Is there any kind of repair to do instead of buying a new one?
Thanks in advance, regards!
Are you sure it isn't a bent spr02?
hanulec is offline
Old 09-10-2013, 02:00 PM
  #4280
columbia-mk2's Avatar
All spr02 habe been checked as per instructions from Oleg in post number 3801.
I will say that my damper is around 35 to 45% weaker than the others, very easy to feel it in the hand.
Thanks for the advice!!
columbia-mk2 is offline
Old 09-10-2013, 02:31 PM
  #4281
dizzy1's Avatar
Trader Rating: 29 (100%+)
Thanks Brent, I'll start with your setup and go from there. Are most people now going to the shorter links? Is that mostly for asphalt or carpet as well?
dizzy1 is offline
Old 09-10-2013, 05:16 PM
  #4282
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Okay Mike
I switched over from bbbb what ever that's....
Attached Thumbnails Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-001.jpg
OVA is offline
Old 09-10-2013, 05:31 PM
  #4283
Track width is pretty narrow in the A700, even with four Xray (#305380) wheel shims in each End of the Car...
Old 09-10-2013, 05:49 PM
  #4284
hanulec's Avatar
Originally Posted by OVA
Okay Mike
looking good...
hanulec is offline
Old 09-10-2013, 05:51 PM
  #4285
It will need a CF shaft v2 soon...
Old 09-10-2013, 06:29 PM
  #4286
hanulec's Avatar
few new setups from the boys at Middle River Hobbies (Maryland) and 5280 Raceway (Colorado) -- http://www.awesomatixusa.com/p/setup-sheets.html. there have been some serious laps turned recently leading up to IIC.
just a bit more detail about these latest setups. Matt Abey's setup is an 'easier to drive' version of Mike Gee's setup from August. Gee's new setup is about 0.1s quicker in 17.5 than his prior.
hanulec is offline
Old 09-10-2013, 07:07 PM
  #4287
Trader Rating: 27 (100%+)
Regards!
After 10 months - I would be sure to look a 2nd/3rd time at Spr02 and SPR01. While the orientation of the SPR02 might look correct when attached to the dampner you might find it has some deformity that will lead to an uneven rate.
SPR01 and SPR01s might result in the same.
Although some of the initial dampners would weap beyond the oring, many of them were just bleading out excess fluid. The revised orings and dampners showed less of that trait.
I didnt read far enough back to see if you were using the original dampners or the newer two piece units - regardless I would suggest that replacing the dampners to the new revised #6 or #3 units.
Page 11
It was a freak thing. I didnt hit a thing. The set screw of the spur axle loosened, the set pin disengaged and I was running FWD. Pretty fast for FWD only
Thankful that Awesomatix USA is close by to fix humpty dumpty. Read for the next round.
Thus why I like AWD! Thanks Limmer.
MDawson is offline
Old 09-10-2013, 07:12 PM
  #4288
OVA
OVA's Avatar
where's the video?
OVA is offline
Old 09-10-2013, 07:57 PM
  #4289
Here they are: stock:
Http://m.youtube.com/watch?v=LtEFpMf6qzM
Mod:
Http://m.youtube.com/watch?v=o732hWG8k4E
Old 09-10-2013, 08:38 PM
  #4290
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
13.5 or 17.5 next round?
Your car looked great in round two. Too bad about the main.
IIGQ4U is offline
