Like Tree3Likes
Tamiya TRF415
Old 03-14-2004, 12:56 PM
  #1306
Regional Moderator
Originally posted by Al75
Here is the new version of the Tech Racing MY02
http://www.tech-racing.co.jp/my02m.htm
Is that reminding me something ???
By the way it is much cheaper than a 415.
NOT to be rude but if you look a page or 2 back you will see this has been posted about 3 times or more now and its a conversion kit for the tech car for people that has already have the car ! NOT a full kit
Ko Racer is offline
Old 03-14-2004, 01:36 PM
  #1307
black-knight's Avatar
Default Re: Belt ???
Originally posted by LeoChan
My 415 use 12T motor play about 30packs battery ,
the Front belt will too long .
Have u tried retensioning the belt?
black-knight is offline
Old 03-14-2004, 04:31 PM
  #1308
JimmyMac's Avatar
Well I broke the first thing on my 415 today. A front body post. hehe.. It was a low speed hit dead into a metal corner dot that was sticking up. The post was cut clean in half where the lower body pin holds down the foam bumper. Oh well, I have new ones...
Anyways, just been playing with setups and I finaly think I have my 415 handling as good as my Yok SD. More testing and tuning needs to be done though.
Question for you guys. On the setup sheets, they would call for like 2mm rebound stroke. Or 2.5mm... or 3mm. Anyways, I've always wondered how they came up with this measurement since it's not measure like droop? After reading the instruction booklet over and actually reading the small tuning guide... I was wondering... do they measure it by measuring how far the droop screw protrudes down from the arm? Like the stock setups calls for 1.5mm front and 3mm rear. So on say.. Surikarns setup.. it would be 2mm front and rear that the screw would be protruding underneath the arm?
Well let me go clean off the car and replace the body post....
JimmyMac is offline
Old 03-14-2004, 05:16 PM
  #1309
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
I think what they do is set the ride height with a race ready car, then pull up on the shock tower untill the tires start to lift off the table. Then take the ride height when the suspension is at is maximum travel, then subtract the original ride height from the ride height at maximum travel.
Just in case this is hard to follow, lets say you have a ride height of 5mm eith everything in your car. You pull up on the shock tower (or lift the car with a hobby knife) untill the tires start to lift off the ground. Now it's at 8mm, so you subtract 5 from 8 and you get 3mm. And that is your rebound stroke. This is the way Difuser told me how to do it, and thats how I measure droop/or suspension travel ever since.
-Sushi Boy
Korey Harbke is offline
Old 03-14-2004, 08:48 PM
  #1310
JimmyMac's Avatar
That's how I thought they did it before. Measure ride height. Then keep sliding the ride height gauge under til the tires lift up. Then subtract. But, I'm not sure now after reading the Manual. I'd just like a "true" clarification on the exact way they do it for the setups. So I dunno...
JimmyMac is offline
Old 03-14-2004, 08:56 PM
  #1311
D_Ames's Avatar
So is everyone abandoning the EVO III now that this car is out??
D_Ames is offline
Old 03-14-2004, 09:03 PM
  #1312
Hebiki's Avatar
Trader Rating: 26 (100%+)
here's a somewhat related question. when you keep pushing the ride height gauge, and the wheels start to come up....
how do you fix it if one of the tires come up first? i know this means the chassis is tweaked. and you need to play around with the shock collars and the tension on the springs, but how do you do it?
sorry rod, i know you showed me last time but i forgot. thanks for the help ahead of time.
race report: my 415 finished 1st in the B-main at the OC Circuit race this sunday. VERY HAPPY WITH THE CAR
Hebiki is offline
Old 03-14-2004, 09:05 PM
  #1313
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Very good sushi boy
OVA is offline
Old 03-14-2004, 10:12 PM
  #1314
I'm selling my Suriakrn Edition Evo III so I can get some $$$ for the 415, but I still would run the car if I had enough money to just buy a 415. The Evo is an awesome car, I'm just kinda low on dough.
-Sushi Boy
Old 03-14-2004, 10:13 PM
  #1315
LeoChan's Avatar
Yes have this belt
my car total play 40packs battery but used 2 Front belts.
about few pack will change F belt .
LeoChan is offline
Old 03-15-2004, 12:55 AM
  #1316
buboy28's Avatar
Arrow
nope not me i'm still gonna keep my EVO III and get me the 415 so that i'm will have the best of both worlds (shaft and belt Driven cars)
buboy28 is offline
Old 03-15-2004, 03:16 AM
  #1317
rccarracer's Avatar
Yes have this belt
So you've already gne through 2 belts, and the third is on the way out???
Are they just stretching or are they breaking in the end??
rccarracer is offline
Old 03-15-2004, 03:40 AM
  #1318
Also on the tamiya setup sheets when you see the part about C1 and C2 front steering blocks does it mean right and left when you look at the front of the car or right and left from the back of the car looking forwards? Rick
Rick Draper is offline
Old 03-15-2004, 03:47 AM
  #1319
rccarracer's Avatar
I've always considered it as they way you look at it on the setup sheet, so this means look from the front of the car.....
Old 03-15-2004, 03:55 AM
  #1320
LeoChan's Avatar
Now used 2 belts coming next belt.
easy to long !
my friend use 23T motor same about 50pack battery will too long !
can't use !
LeoChan is offline
