Xray T2'008
#1666
I just finished building my new 008 and gotta say one of the best cars I ever built!!! Was wondering if the fixed piston or the adjustable piston in the shocks if one is better than the other?
#1667
The Evicerator
I prefer the feel of the fixed piston as long as you're fairly settled on a shock setup.
If you envision yourself wanting to do lots of piston hole/dampening feel changes then the adjustable ones are nice for that.
#1668
Thanks Steve, I see what your saying. I think I'll use the adjustable ones for now to see what setting works then use the fixed piston when it's sorted out. Also Steve I want to Thank You guy's at Novak for the great customer sevice and FAST turn around
#1669
hi dudes
On most of the latest rubber indoor carpet setup team drivers prefers +0.75 roll centre (lower)
why is that? To get rid off extra steering or grip???
cheers
cheers
#1671
#1673
for running the brushless motors 13.5 and 17.5 to get the FDR right. Also with the 34/20 pulleys theres less wear on the belts and the drive train seems more free.
#1674
if track is bigger will use 20T center pulley,
but if small track with hair pin ... use 2.375 gear ratio
