1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2895Likes
Old 08-20-2013, 04:36 AM
  #9256
Originally Posted by simmo0916
Hi guys, Me again with a quick question - Can anyone tell me why you should drill holes in the wheels when putting the Pit Shimzu tyres on?
Is it as obvious as helping heat dissipation, or are there other reasons?
Cheers!
It's to let air in and out. If the holes weren't there the weight of the car will push air out of any small hole it can find as the tyre squashes. If there is no hole the air can't get back in and you end up with a squashed tyre.
terry.sc is offline
Old 08-20-2013, 04:56 AM
  #9257
Gotcha!
Should I be putting in 1 hole or more? How big should the hole be? I have drilled one 3mm hole in each wheel so far.
simmo0916 is offline
Old 08-20-2013, 09:56 AM
  #9258
Or if you seal it real good then the tire bounces like a basketball...not real good for the handling
InspGadgt is offline
Old 08-20-2013, 10:48 AM
  #9259
Mechintosh's Avatar
I use 1 hole, about 1mm in diameter.
Mechintosh is offline
Old 08-20-2013, 03:11 PM
  #9260
I use two 3mm holes opposite each other, to help balance out the loss of material. The foam in the tyre keeps any dirt out.
A UK specific problem, but having bigger holes also makes it easier to get the water out after racing in the rain.
terry.sc is offline
Old 08-21-2013, 03:47 AM
  #9261
Default Yokomo 001n Set Up
Hi,
Would anyone have a good starting set up for a narrow/rubber 001. I will be running on indoor carpet with low grip..21.5 motor with shorty lipo and laydown servo.
I had a look on Petitrc but can't find any rubber indoor setups?
Any tips also welcome as this is my first F1..
Thanks,
Keith
kdempsey is offline
Old 08-21-2013, 09:04 AM
  #9262
Many thanks, I have done the same, two 3mm holes opposite each other. It annoys me that I have to wait another couple of months until I can actually run this car!!!
I see you are from the UK - Any decent tarmac tracks up your way?
I'm having real problems finding anywhere that has on road racing
Old 08-21-2013, 10:03 AM
  #9263
If you fancy racing an F1 on tarmac, realistically your only choice is the Stafford summer series. Even Stafford goes indoors in winter. Most racing is done indoors on carpet, the F1 Nationals is at Tamworth. If you are looking for somewhere racing F1s, you will find there are very few clubs that run them. For normal club racing I will be running my F1 on my own as I'm the only person here still running F1, so outside the big meetings I usually race 1/12th or WGT.
To find somewhere I would suggest starting with the clubs list here, although it is quite old and a lot of clubs don't exist any more. You do find a lot of clubs are concentrated in particular areas, with big gaps in between. Here around Manchester I have the only on road club, but nearer the Wirral there are several on road and not much off road.
terry.sc is offline
Old 08-23-2013, 06:24 AM
  #9264
Need a little help.......have an F104W with the Wolf body. I remember reading somewhere on this thread that the kit tires that come with the car are crap, and
need to be replaced. What are the tires I should get?; and bear in mind that I'm looking for the wider tires that fit the 70's era of that car. The car will be raced on an asphalt parking lot
Team Lotus is offline
Old 08-23-2013, 06:39 PM
  #9265
Marty Peterson's Avatar
Just to toss this out there ok.
I am selling my Speed Passion SP-1 F1 Competition RC Racing Car with a finished VF1 body & 1 Un-finished VF1 Body. Speed Passions Reventon ESC (brushless) Speed Passions 21.5 Motor 2 sets of wheels and tires, With Servo Futaba 9602.
One Run about 100 feet down the street and back.
LMK Email me for Trades or cash.
http://lee2763.smugmug.com/Other/199...3844&k=WrwNqmW
http://www.ebay.com/itm/200955976045...84.m1555.l2649
Marty Peterson is offline
Old 08-23-2013, 09:11 PM
  #9266
What?!?!? Why?
Old 08-24-2013, 10:42 PM
  #9267
Originally Posted by InspGadgt
What?!?!? Why?
Well I can't get to the track to run or test and all the people around here are running on road cars in the streets and local parking lots around my house.
Old 08-25-2013, 09:03 AM
  #9268
You want wheels and tyres for the F103. Pit Shimizu makes F103 equivalents of their F104 tyres, with similar part numbers. Part number 571 and 572 are the popular F104 tyres, so for the F104W you want 541 and 542 tyres for the F103, and a set of F103 wheels made for foam tyres. Rear tyres are 5mm smaller in diameter than the kit tyres, but the motor pod will let you lower the axle to use them fine.
terry.sc is offline
Old 08-26-2013, 11:50 AM
  #9269
Cadman1981's Avatar
I posted this in the F104v2 forum, but i'll share it here as well since it's the general F1 group. I have been struggling with front end grip, and i have tried all sorts of front tires, but recently read that Caster helps with these cars, so i found out you can make top arms from some parts i already had, here's my result
I have noticed my front tends to "hop" a little making my car push, i'm hoping this will help me get a better setup, and i will also try to move my shorty lipo as far forward as possible by removing the tabs on my servo and bringing it another half inch forward.
Cadman1981 is offline
  #9270
Cadman1981's Avatar
Whoops, double post
