electric stadium truck >
Old 11-15-2008, 01:35 PM
Red face electric stadium truck
Hello i need some advice please i have a losi xxx-t and want to go brushless in it and lipo what motor and battery combo do you suggest and also what pinion gear to run? thanks alot for your help been in r/c for about 4 years now but wanting to get a little more serious with it.
ripnroar is offline
Old 11-15-2008, 01:39 PM
Trader Rating: 23 (100%+)
well, what motor do you want to run?
not home is offline
Old 11-15-2008, 01:55 PM
either novak or castle creations which one do you recommend or any other.
ripnroar is offline
Old 11-15-2008, 02:12 PM
you going to bash or race? first race? stock mod motor? what do u wanna do?
not home is offline
Old 11-15-2008, 02:24 PM
I want to race.
ripnroar is offline
Old 11-15-2008, 02:46 PM
Then get a Novak motor, LRP, Novak, or Tekin ESC, and 2 Orion 3800 lipo batteries. You will also need a lipo charger and low voltage cutoff. you should buy a bunch of pinions and see what work best fr your track.
Chris__RC is offline
Old 11-15-2008, 02:59 PM
which of the novak systems would be good? and thank you for all the info.
ripnroar is offline
Old 11-15-2008, 03:06 PM
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Don't the current ESC's have a built in Low voltage cutoff these days?
y2kgtp is offline
Old 11-15-2008, 03:20 PM
Get a new Novak GTB with the lipo cut off and a 17.5 motor. Get the orion 3800 30c and hopefully you already have a charger that charges lipo. Then gear it around 7.0 final drive. Id say 28 pinion 82 spur is a good start!
dennyboy424 is offline
Old 11-15-2008, 03:50 PM
thanks for the info i now have access to use a novak 10.5 brushless pro motor and novak esc what spur and pinion gear should i use with it.
ripnroar is offline
Old 11-15-2008, 03:51 PM
All depends on the track.
Old 11-15-2008, 05:03 PM
with a 10.5 start with a 22 pinion 82 spur. If you want a hair more punch go to a 23 tooth pinion but its hard to keep the front end down
Old 11-15-2008, 06:02 PM
yeah thats probly the best option
nhjake is offline
Old 11-15-2008, 06:47 PM
thanks alot for the info. does losi make a 82t spur gear i think now i have a 88
ripnroar is offline
Old 11-15-2008, 06:49 PM
they do, 88t spur means u cant fit all motors in.
not home is offline
