Avid brakes
Avid brakes
has anyone tried these brakes? worth buying or keep stock?
also, I read on their site as follows. Talking about removing the padded material. I have not messed with the brakes on my losi that much and im wondering what its talking about??
copied from avidrc.com:
Installation: In order to use these discs you must remove the padded material off of your metal pads (your removing the pad that you usually have to glue onto the metal pads). So when you build your brake setup it should be the metal pad touching the Avid Indo Phenolic brake disc and nothing else. We suggest that you build the brakes with a 0.5 - 1.0mm of play so when the car is at neutral your brakes are not engaged.
http://www.rctech.net/forum/nitro-of...id-brakes.html
You will find more feedback in that thread.
What it means is that you will use the disks with just the metal pad, the padded material is not needed. As soon as you see the brake pads you'll understand what it's talking about.
The losi brakes are the best, they were a running change so I'm not sure which ones you have.
http://www.amainhobbies.com/product_...Set-20-Updated
X2...i Love em and would take them over a fiber disc ANY day of the week.
