ROAR Approved Chargers
Are there any ROAR approved chargers? I was told tonight that my charger is NOT legal, because my batteries off the charger was 8.5V. I'm new to LIPO's and all I did was set my charger to LIPO and start charging the LCD displayed 8.4V.
Andy, If you went to tech and your batteries were 8.46V, what would you do to get your batteries to 8.44V?
There isn't such a thing. Approved motors, batteries, bodies, yes. Chargers, no.
http://www.roarracing.com/?page_id=14
ROAR rules for 2010 state that the maximum voltage for LiPo is 8.40v for 2s, 4.20v for 1s. No wiggle room anymore. Also, a maximum charge rate of 1C.
Turn on your car and yank the throttle until you meet the rules. However, at some ROAR races, they may DQ you if you are over voltage when you come to the tech table. What I suggest is to have your own volt meter, and "calibrate" it to what the official meter reads. For example, if the official meter reads your pack at 8.42 volts, but your meter reads 8.40 volts, you better make sure before you go to tech your meter reads 8.38 volts (0.02v "offset" from the official meter).
What charger do you have? Some higher end units are adjustable.
I was looking at the rules and it states 6 Nimh or 2s Lipo. Is there any mixing of batteries? Nimh running with Lipo
I just looked at the manual and didn't see anything to adjust or calibrate the cutoff voltage.
What I mean can I have Nimh in my car and you have Lipo's in your car?
Hmmmm...TP makes good products so I am a bit surprised.
The online manual says that you can indicate percentage of charge. You could cut down on the charge that way. Read your manual for details.
Another thought is for you to check the voltage with another multi-meter. Theirs could be wrong.
Bill
Bill
