Modified motor forum.
#106
Joe, I want to try narrowing the brush like you said. Approxmiately how much diameter should a guy take off of the brush? .010? .020? It sounds like drilling a hole would be the easiest for me, is there a particular size drill bit you would suggest? As always thanks for being so helpful online answering questions! We are getting pumped for the nats!
racer-oZ
racer-oZ
#107
Originally posted by Joe Pillars
Drilling a hole in the brush should work also.
#108
racer oZ-I would narrow the brush .30mm
jkerr0043- Both brushes. I have been to RC Heat once, the weekend before the Reedy Race. Definitely run hard springs and sprint brushes with the timing at the third line. Good Luck!
#113
info on V2's
modifides= 5mm armature blank w/ enduro brushes
tourings= 4mm armature blank w/enduro brushes
surikarn/hara/spashett=4mm armature blank w/sprint brushes
all motors come with med/hard springs
speedxl try a 7.8 ratio to start then adjust accordingly
#114
Originally posted by jkerr0043
You should have seen Hara out motor every Reedy car out there this weekend. It was amazing!
look at cavalieri he ran a 9x2 and smoked the open class \
#116
Originally posted by Andrew Swanson
its easy to out motor everyone when you run a 6 or 7 compared to a 8 or 9
look at cavalieri he ran a 9x2 and smoked the open class while orion driver thrue ran a 7x1 why does he need so much more motor.
#117
jkerr-always a pleasure where else do you race??
#118
faster isnt always better.
#119
Where ever I can If there's a local parkinglot race I'll try and run there but I race a lot at the RC Heat parking lot races. I'll run at La Mirada from time to time. I can't really afford to do too much traveling but I do what I can. I don't run at SoCal very often at all. That track and I don't get along at all. I also run offroad at a small off road track at Family Hobbies about 5 minutes from my house.
#120
cool i will be venturing out to rc heat for the first time this sunday cant wait heard nothing but good things
