Why 1/12 scale less popular on asphalt ?
#16
The other reason we prepare tracks - tire wear is significantly reduced. If you're running a pan car on asphalt, you'd probably appreciate having to use fewer tires to get through a race day.
#17
On some asphalt surfaces you can. When I first started racing pan cars all we did was blow off the track with a leaf blower and traction was sufficient. But it seems something has changed with asphalt in the last 20 years to where now there is literally no grip even with the softest tires and setup without doing some sort of prep. All you will end up doing is having cars that are extremely loose to drive and that's not fun.
#18
We used to have some clubs that raced 1/12th on asphalt in the UK. Every one ended up with a custom built chassis with a long wheelbase and the motor behind the rear axle to get them to work.
#19
double post
#20
In the UK we don't run 1/12th outdoors as they are undriveable. Any racing would end up being who manages to run for the race with the least spins.
only way to run 12th on asphalt is by having some seriously well looked after asphalt lol, a single stone and you are gone..ive tried it as have many others
i mean look at the outrage it caused on here by having the IFMAR 12th outdoors on asphalt in 2014 lol
#21
Id say because 1/12th is generaly bigger in the northern (colder) states... therefore its a wintertime and indoor thing brcause most guys are doing other things in the summer since its limited on time. Places where its nice like florida and cali have great outdoor tracks but nitro is bigger since you can race year around
#23
Castor oil with simple mixture of sugar water nothing major
To me the best recipe is properly blowing off the track
#24
We vaccuum our track and spray it with sugar water every race day. It is a good 2 hours worth of work and I'm really thankful to the racers who help out every race day. Without them we probably wouldn't be racing right now. I would have got burned out long ago.
#25
I'm in the UK. If we sprayed the track with sugar water, for most of the year it would still be wet at the end of the day.
If anyone has a wet setup for 1/12th we might be able to run them outdoors more than a handful of times each year.
#28
When there is the turn out this is one of the classes I have enjoyed the most. It just requires as stated....tuning your car around the track for looser conditions. It can be though.
#29
Have you tried F103s on rubber tires and unprepped asphalt? That's not so good either. I've heard of some people using rubber capped tires with some success but I have no desire to spend $20 per tire just to try it out. Sweep was working on a rubber tire for 1/12th but I haven't heard anything on them for a long time. Most likely they gave up.
#30
