Tekin RS ESC sensored
My RS has the first two and last two lights flashing and the motor wont go unless I give it a little help by turning the wheels. It ran fine the first two races and then wouldn't run for the third? According to the Tekin website this error code could mean that I have the wrong motor selected but when I checked it with my hot wire it is set for brushless. I've tried a new booster, receiver, sensor wire and a known good motor with no avail? Any ideas or help would be greatly appreciated..
Bob
Also if I turn the switch for the speed control on first the lights flash correctly on the speed control. If I turn the booster on first it flashes with the error code I noted above, but either way it wont run!
Bob
Just want to Thank You Tekin! I just installed the Hotwire with no problems. Now Im ready to learn and play. I now need some good set ups for WGT and 12th mod. thanks!
... Eagerly awaiting!
What size wire should I use for Blinky 17.5 TC?
12 to 14 awg wire should be fine
I don't run F1, but what size track are you racing at? (this might help someone else give you a starting point).
Also if you are using foams, obviously gearing will play into the setup too, as they wear down.
The cars are quite light so you might need to use less boost than other classes but again it really depends on track size and the length of the straight and so on....
As for delay. I would possibly try 0.3 as a starting point, ramp 2 and go from there but it is a guess. Watching motor temperatures is also a key point.
Up in smoke
Mixed up my battery leads and smoked my tekin I heard some one say that all you need to do is replace the Capacitor and your golden. thanks.
IT's possible but don't hold your breath. Replace the cap and power it up, if it works consider yourself lucky, you dodged a bullet.
Now blinky class - don't get me started.
specs
my damn hobbywing just blew on me. you buy cheap you buy twice is so true. i am seriously considering a tekin RS pro, but whats puts me off all ESCs nowadays is the information on the website, they dont list everything i want to know. like on the tekin website, there is only 1 page showing the RS and RSpro together, with basic specs. i wished they would have one complete page for the RS, and another for the RS pro, with ALL the info on them, like info about boost and turbo also. What is the weight of the RS pro without wires ?
