Spintec Battery Manager
#241
I think the idea is to offer this to racers that do not have a GFX ( and or high rate discharger) and as a alternitive to "just traying" after a run. The system is new and with that will come a learing curve as to what to do and what not to do.
I have just received my unit ( Thanks Erik) and will start using it right away.
I don't think pics do the discharger justice, it is really small and very easy to use. the LED data window is easy to read and the scroll of the data is a nice feature.
For racers with Muchmore/LRP/Novak etc chargers this is going to be a must have item.
#242
#243
Guys dont rap the product unless you have tried it.
Everyone seems to focus on the 35A discharge. However no one seems to note the decrystalization process.
I was amazed when I started hearing the clicking sound, not to mention that my packs were cold after discharging.
Now these two observations alone you do not see with any other discharger/charger on the market.
Whether it works or not is up to you to decide. However the tangible results of discharging (cold packs and the clicking) process alone make it something very different.
I dont own one yet, but I have been using my friend's BatMan. I might get one of my own in future if it proves to work well in the long run.
#244
I don't think anyone is negatively commenting on the Spintec. That is the whole benefit of the Spintec: to decrystallize the cells. If you discharge the battery on a GFX to 5.4v why would you use the Spintec since .3v is not enough to make much of a difference in the cells as opposed to hooking up the battery to the Spintec from the start.
You might as well take advantage of the dicharge and cooldown blocks on the Spintec instead of using a different discharger for all but .3v.
#245
I agree. That's what the Spintec is all about, to decrystalize the batts. If I can effort to, I'd also fully charge a pack of batts and then put the Spintec on just to get it decrystalized. But for only 0.3V, I think don't waste the time.
#246
"decrystalize" ... that caught my attention... so in essence, lower IR? or higher capacity?... do they have a website where i can get more info? thanks - jason
#247
#249
Thanks... got to read up on the product and company...
im sorry if it has been discussed before, but how does their discharge differ from others? as i understand it, the 35 amp discharge is done in bursts?? is this correct? if so, does this mean that it takes spintec longer to discharge a fully charged pack?
how does discharging in bursts, "decrystalize" the cells?
thanks again - jason
#250
What it does...
This is from my personal experience and it seems to be consistent and not a one time effect.
I have 5 GP3300 packs that were not accepting more than 3300-3200 mAh and were having a lot of trouble delivering 5 minutes on the track.
I discharged what was left in them with the BM. After that the packs accepted more charge and the Peak Voltage was lower than it used to be.
Then I charged them completely and discharged them with the BM. It takes a couple of hours to discharge a fully charged pack.
Now, ALL 5 accept around 3800-3900 peak at around 9V (not 9.3 as they used to) and on the track they almost seem like barely used packs.
Run time is not an issue with 4 of them and the punch is awesome.
Now I'm using the BM ALL THE TIME after running with the GP3300 and the GP3700.
It seems to me that I've found the right tool for the job.
#252
Yes it takes longer to discharge with the BatMan. The advantage is that the cells do not heat up, so if you're in a hurry, you cant use the BatMan.
#253
EAMotorsports
RCmodel-hk does have them in stock. I just ordered one from there site the other night and they shipped it the next day - but I already had an account set up with them. If you are having problems send a PM to HKRCMODEL on here or tell him the problem under the "Whats new @ RC Model" thread. He can help you out.
#254
Hebiki, thanks for the review. Very nice!
Korgae, good to hear you received it. Looking forward to your findings!
Hello Antonio! Thanks for your explanation!
For the US guys, there will be a large shipment to Horizon next week. So very soon you can easily order them through your local hobby shop!
#255
Hello,
Maybe this is already answer, but I go:
-It is prove that the BM increase the performance of an old pack, but what happend when you use with a new one? Does it also increase the performance or just keep the same level for more time?
-By other way how many "cycles" are need to get the maximun performance?
-When will be available for 4 cells?
Thank you very much
Thank you very much
