TC3 Forum
#9661
Re: Mod to droop screws
Originally posted by marzin
Hi Guys,
Mod to droop screws?
I hv got a TC3 without droop screws, still using the shock limiters.
Can I convert the arms to use droop screws? Buy the Ver2 arms?
Any ggod ideas to go about it?
Thanks for any help
Cheers
Hi Guys,
Thanks for any help
Cheers
#9662
Hi diskostew,
Thanks dude, anyway to skip the new style chassis?
dremel ?
dremel ?
#9663
Hi Guys,
Thanks for any help
Cheers
Hi Guys,
Thanks for any help
Cheers
#9664
oops
#9665
Aluminum Steering Rack
Who makes an aluminum steering rack for the TC3?
#9666
Fastrax millennium FTTC08 if you get it replace the plastic bushings i think or plastic washers as they fall appart after 1 race with all the original parts of the std steering rack. Then its sweet run bearings then u will be laffing
#9668
its hard to say with out having the car in front of me but check and make sure you have proper gear mesh between the spur and pinion and make sure thier are no small rocks in the teeth of each of the gears if all that is set good move on the the diffs, i would take all the cvds out and put in an outdrive at a time and spin it so you can pinpoint the problem more accuratly! hope this helps
#9669
does anybody have problems with stripping the screw holes on the tc3 diff cases? i have like 2 striped holes on both cases! its such a pain!
#9670
Rc Guru check you Cvd's the pins are probably rubbing against the C huds, also check your gear mesh, it could be a combination of both
kh15, yes the diff cases strip very easily in my opinion, you have to be careful all the time with them, i find myself puttin dabs of CA glue on the screws before i put them in alot after i strip them
#9671
with those diff cases.......use the long end of the allen wrench....and turn it only as far as it can go...maybe just a little less...thats how you dont strip em.
THANKS for the advice guyz....maybe ill just go into the diff right away since its raining here....erg...so hard to take the damn diff out..lol its alot harder then my team losi xxx bk...yeh i checked my gear mesh..some reason it keep getting loose? hmm...i think its time the screw meet mr.locktite
#9672
Hi Guys,
Got some noob questions regarding the Droop settings if one could help:
1. Any difference in handling for the car with Shock limiters and droop screws on arms? (besides easier to adjust)
2. Wats the droop measurement on the standard shock limiter setting?
3. Are the AE droop gauge (measurement) different from the common ones like tamiya, integy etc...
Thanks Y'all !!
Thanks Y'all !!
#9673
what are good springs to use as a starting point for carpet racing?
#9674
If your looking for a foam setup, take a look at Mike Blackstocks setups.
Jimmy
#9675
whats better to use on carpet rubber or foam?
