Mamba Max 7700Kv
Old 08-01-2009, 12:40 PM
davidg01234's Avatar
Default Mamba Max 7700Kv
Im getting the MMM 7700KV for my hyper 7 soon, how long can i run it with a 3 cell lipo without the motor overheating
davidg01234 is offline
Old 08-01-2009, 12:50 PM
Trader Rating: 17 (100%+)
I would guess about 30 seconds. That motor is designed for lightweight cars and low voltage.
burnineyes is offline
Old 08-01-2009, 12:54 PM
Well how many volts can the motor hold for about a 15-20 mins run time , im new to electric and dont know much, please help
Old 08-01-2009, 01:14 PM
Trader Rating: 21 (100%+)
Have you looked at some of the conversion kits? That would help you get familar with the pieces and type of motors, lipos and escs being used.
The MM 7700 is intended for something light weight like a rustler and 2S lipo and other light weight 10th scales.
Your hyper is going to prob be running 4S lipo and will need a 8th sized esc.
Duster_360 is offline
Old 08-01-2009, 01:24 PM
ya i have looked at them
OHH ok i didnt realize it was for 10 scales
what about the 2200kv motor, how many volts can it take for about 20 minute runs
Old 08-01-2009, 01:33 PM
this'll give you some idea about the MM7700- Currently I have one installed in Tamiya Mini Cooper w/2s 4000 and it'll do about 18-20 min (depending how I drive it) but at 40+ mph - which is flying for something that size and hard to keep it on the ground, the batt goes real fast.
bowl806 is offline
Old 08-01-2009, 01:42 PM
Well i cant use a 7700 because its for small vehicle im gonna get the 2200 for my 8 scale buggy, ahh this electric stuff is confusing.
But can somebody answer my question, if i am even asking the right thing
How many volts can i use on a MMM 2200kv for about a 15-20 minute run without burning the motor up?
Am i asking this right
Trader Rating: 23 (100%+)
get the MMM 2200kv system, its a beast, and will be perfect for you setup. Or if you really want to haul A%# get the 2650kv setup, run time with a 4s will probly be 8-10 minutes, depending on driving conditions and battery used
JATOdriver is offline
Old 08-01-2009, 01:46 PM
What does 4s, 2s, or 3s mean
Old 08-01-2009, 01:53 PM
With the 2200 you will likely want a 4-5s pack. That means a 4cell or 5cell Lipo. That is 14.8 volts or 18.5 volts. The 5s may be a bit too much, but it will fly!
Old 08-01-2009, 01:55 PM
about how long will that last at normal bashing (jumping ramp, up and down street stuff like that)
Old 08-01-2009, 01:57 PM
how come on the website is says the motor can hold a max of 25 volts
Old 08-01-2009, 02:08 PM
Sure! you can put a 6 cell lipo which is 22.2 Volts on one. But it will be so fast its not controllable. Or maybe 20 Nimh cells for 24Volts! The extra weight would cause parts to break much faster, and slow it down alot. The 25V rating is for speed freaks like myself who want to put one in a 1/10th scale car and stack batteries up to see what we can explode! Thats really all that raing is good for. stick with 14.8-18.5 Volts and you will go plenty fast to beat nitros and still be driveable.
Old 08-01-2009, 02:12 PM
Im a speed freak to, but when i was with nitros it just want fast enough so im going to electric to get more speed.
Will the 6s lipo burn the motor up? and wont it give me longer drive time than a 4s or 5s
Old 08-01-2009, 02:29 PM
cell-
bowl806 is offline
