TC4 Front CVD replacement options >
Old 06-25-2016, 11:54 AM
Default TC4 Front CVD replacement options
Hi Folks. New to the forum but old in RC racing.
I have a brand new TC4 that I am loving so far except one thing. The front cvds don't have enough travel in them for full steering. I researched and found the LOSA 3344 trick, but those parts are near impossible to find now, and saw a Youtube vid where a guy fixed it using Associated parts, but he didn't list part numbers or what they came off of, so not much help there. I would like to run full steering and not adjust with dual rates. Does anyone know of a solution with a different double-jointed part than the 3344?
Derfel is offline
Old 06-25-2016, 01:31 PM
There are really two tc4 DCJ mods:
#1: BERT mod losi losa3344...
#2: Will mod tc6.2 DCJ(#31632)+ tc6.2 steering hubs...
The Will mod might also clear the way for you to use other manufacturer's DCJ drives with 5mm axles, but you will need to fit/shim them correctly... Cheers.....
bertrandsv87 is online now
Old 06-25-2016, 01:39 PM
Awesome. Thank you so much for your help! Do you mean the caster blocks, or the steering arms?
Derfel is offline
Old 06-25-2016, 02:04 PM
Lightbulb
Check out TC4 thread, TC7 arms and CVD's
THEBIGBULL is offline
Old 06-25-2016, 02:46 PM
patorz31's Avatar
Tc7 arms chubs steering knuckles and dcjs. It a laundry kist of parts but it will work.
patorz31 is offline
Old 06-25-2016, 03:20 PM
gigaplex's Avatar
You probably don't need the TC7 arms. TC7 knuckles plus either TC7 or TC6.1/6.2 C hubs are probably sufficient. You can use TC6.1/6.2 knuckles but the TC7 ones are closer to TC4 geometry regarding bump steer. You'll also need appropriate hardware (eg ball bearings, king pin bushings).
gigaplex is online now
Old 06-25-2016, 07:04 PM
Not the caster blocks. Steering arms/hubs are where the bearings fit to hold the axles... There seems to be another tc7 DCJ mod coming up for the tc4 soon... The tc4 is so versatile....wow.... Cheers....
Old 06-27-2016, 09:37 PM
1spunspur's Avatar
Hi Derfel; there is a TC4 thread in here that beats this subject to death. I have a TC4 and never had this problem. The thread address's using double jointed CVJ's and using a dremel tool to shave a a little off your steering knuck's to rid yourself of this problem.
1spunspur is offline
Old 03-27-2019, 01:56 PM
I know this is old but looking for that thread, just picked up one for cheap and looking to see what can be done. Thanks.
Let the flat side drag!
cphase is offline
Old 03-27-2019, 08:21 PM
gigaplex's Avatar
Team Associated TC4
