XRAY T2’009
#2222
I need some gearing advice. I have a 17.5 lrp motor and a techin rs pro ecs. What gear ratio should I try. The track I run at has long straights and two chicains. What internal ratio should I have 1.7 or 1.9. Thanks a lot in advance.
#2223
#2224
reduce front end wobble
my front end wobbles alot, but only on 45° or more steering. I heard the ECS shafts help out alot, but are very expensive.
Is there a quick and cheap alternative to fixing this problem? I know cheap and xray dont really go hand in hand
#2225
#2228
thanks guys, the atomic ones look like xray's ECS but half the price, will give them a go!
#2231
Hey Guys,
As always i build and do blogs, currently in progress my new TOY the Xray T2PRO - http://xrayt2pro.blogspot.com/ will get some info attached to photos and setup sheets for the TEKIN speedy....
Enjoy
Frankie
Enjoy
Frankie
#2232
I've got a '009 for sale locally but am having 2nd thoughts. I like how the car works but I've got a problem. It breaks almost every time I drive it. In our 17.5 TC class about 90% of the cars are T2's of some sort, but my '009 is the only one that breaks. C hubs, arms, steering blocks have all broke regularly. The other XRAY guys are shocked mine breaks so easily... I don't get it. Main difference is they have alum steering blocks. Don't want to spend the dough on them if I'm just going to keeping breaking other parts. I spent the money to have tough car.. but this about as brittle as anything I've ever had... maybe the worst.
Some thought it might be the spool so I put in a diff and it still broke. I'm not saying this to knock the car I just have NEVER seen an XRAY break like this.
Any thoughts?
Any thoughts?
#2233
I don't know since Ive had my car Ive only broke a steering block . it be if your running softer parts (medium steering blocks or rear up rights) but truly i have never seen a broken xray arm so im lost with that one
#2235
few things...
1. do 48p gears fiit?
2. how do you guys like the chassis protectors?
3. what would be a good starting fdr and profile on an spx on an open asphault track? its 17.3 with and express duo2 motor.
Thanks,
Hayden
Thanks,
Hayden
