Ask Todd Hodge..aka "Hodgimoto" >
Old 06-02-2004, 12:10 AM
  #676
frank b's Avatar
Default losi outdrive
todd: i was wondering if you use steel outdrive for onroad pavement, and only in mod and if you do please give the part numbers for the outdrives. thanks bud
frank b is offline
Old 06-02-2004, 12:27 AM
  #677
Default Re: losi outdrive
I'm not todd, but you need part numbers losa3072(aluminum diff tube), losa3073(steel outdrives, one per package), and losa6230(shim assortment set). Todd can clarify if I am wrong on any of it.
James Nguyen is offline
Old 06-02-2004, 02:32 AM
  #678
RedRocketRacing's Avatar
Default Tamiya Shocks-
Those of you who keep asking about the Tamiya shocks haven't spent enought time trying to match Losi shock. The Tamiya shock is one of the best on the market. Losi shocks are so bad that is why they came out with their matching tool.
Todd - Any plans on a new shock? Maybe something like the Tamiya or Yokomo? Just Top fill with a bladder and the proper length.
RRR
RedRocketRacing is offline
Old 06-02-2004, 06:14 AM
  #679
TLRacing
Todd Hodge's Avatar
hklosi-Try not using the battery strap and just taping your batteries in. Remove the rear bumper and just cover the bottom with a small piece of lexan. Use aluminum screws or titanium.
invisagod-Trinity makes some and also you can use AE ones if you want to make the car wider.
bestea-Yes at times I will use steel outdrives. Mostly on lower bite tracks where more traction is needed. The part number the outdrive is LOSA3073. You will also need to get LOSA3072 Diff tube for completing the diff.
RedRocketRacing-I don't think Losi shocks are as bad as you say. The shock matching tool is so you can match your shocks when changing pistons so you can match up the oil.
Todd Hodge is offline
Old 06-02-2004, 09:23 AM
  #680
EricF's Avatar
Todd,
Any chance you can/will post the setup that (I don't know if you did) was run at the Reedy... the one with the 2R block up front. I don't recall what some of the other changes were.
Thanks,
Eric
EricF is offline
Old 06-02-2004, 10:03 AM
  #681
Todd, what servo do you run in your 10th scale electric touring car?
aviaar is offline
Old 06-02-2004, 02:36 PM
  #682
Hey Todd,
Do you think running universals rather than cvd's would give more rear traction for a BK2 on pavement?
James
Keyz is offline
Old 06-02-2004, 06:58 PM
  #683
Bink's Avatar
Default Trinity Hex Adaptors
What Trinity hex adaptor part number do you suggest for standard size wheels ¥12mm¤? I have seen part number TMF1123 and TMF1114, but which is the correct PN or best design for the XXXS G+?
Do you run the losi graphite hexs or aftermarket aluminum hexs?
Thanks,
Bink
Bink is offline
Old 06-02-2004, 08:48 PM
  #684
SCIDA's Avatar
I know I asked this on Trinity Tech, but no one is there lately. Why are you so fast? Are you still running THE WHEEL on your M8 radio.
People always try to make their cars go faster but do not put much time into making themselves faster by way of a better feeling radio. If you do still run THE WHEEL could you elaborate on why?
Steve Chamberlain
SCIDA is offline
Old 06-02-2004, 10:19 PM
  #685
frank b's Avatar
todd: i was wondering if you recieved my personal message yet and if you could get back to me.
thank bud
frank b is offline
Old 06-03-2004, 09:43 AM
  #686
Trader Rating: 21 (100%+)
hey todd-
will you have that reedy race setup for us to see soon?
peter_robinson is offline
Old 06-03-2004, 10:25 AM
  #687
rctoyguy's Avatar
Hi all... I am looking for an article that Todd wrote a while back on tuning a XXX-S for asphalt. I haven't seen it, but I heard that it is very easy to understand for someone starting out... sort of a "tuning for dummies" kind of thing... I'm running rubber tires in stock/novice and just getting started in actual racing instead of just running in the street at home.
Any idea where I can find this?
Thanks!
rctoyguy is offline
Old 06-03-2004, 01:07 PM
  #688
frank b's Avatar
Default reedy race set up
here you guys go i have Matt Fracis set up for the race
File Type: pdf
frank b is offline
Old 06-03-2004, 01:23 PM
  #689
frank b's Avatar
thanks todd:
I appreciate that you sent me the set up and i posted it so others can see.
I'd like to say thank todd for going out of your way to send it to me.
frank b is offline
Old 06-04-2004, 07:03 AM
  #690
TLRacing
Todd Hodge's Avatar
Fike-Yea that was David's setup that was used by a few of us including Open class winner Ryan Cavaleri
Front Suspension
Front toe-0
Ride Height-4.5mm
Camber -1.5
Caster- 2
Kickup- 0
Droop-7mm(had 2.5mm of uptravel)
Front Pivot-2R(yes rear block on front to get straight front pins)
Arm Spacing-Middle
Ackerman-Forward and Flipped
Spool with 41t front pulley
.060 washers under bellcrank ballstud
Chrome ball stud with one gold washer on caster block
Camber Link- #3
Shock Position- #4
Team Losi Low Roll Center
Oil-60wt
Piston-#56
Spring-Green
Shock Length-60.5mm
REAR SUSPENSION
Toe In-2
Ride Height-5mm
Camber -1.5
Droop- 9mm of travel(4mm of travel)
Pivot-2R
Arm Spacing-Back
Camber Ball stud-Black
Camber Link 6/A
Shock Position- #4/Outside on arm
Roll Center-TL Low
Standard rear end
Oil-40wt
Piston-#56
Spring-Blue
Shock Length-65.4mm
Body-Mazda 6
Tire Additive-BG2
