Novarossi engines thread
#1111
stay with 16%.....................castor is always nedeed, but 2% is more than enough............synthetic, depending on its quality from 5 to 10% is ok..........
if you can't find 16% fuel, use 20%........
#1112
I will be making my own with Coolpower for the synthetic oil.
#1113
where do you find nitromethane at reasonable prices?????
#1114
So who has the best deals on nova engines.
#1115
#1117
hey guys, I have a novarossi ns12 3 port and having issue with starting the engine. I just send the p&s for resizing and now the engine does not starts. I tried the factory setting lsn 2.25 out hsn 3.5 out and still no go. the turbo plug is fine and tried several, it does get fuel to it and it spins fine but no ignition. of course the glow ignitor is working also. tried different shims from 3mm to 6mm but still not firing. I have tried to richen the needles by up to 2 turns low and high but no go. piston and sleeves looks fine as well.
anyone has any suggestions?
thankx
thankx
#1118
whats some of you guys favorite .12 engine from novarossi, including rex and top versions. and whats you all's favorite modifed novarossi .12's.. talkin 3 ports...
#1119
Originally Posted by josh_c
A good place to get the novarossi is from www.rcmart.com. cheap
If you live in the USA, buy from a US dealer.
#1120
thankx
thankx
#1121
I did pour fuel as well but no luck.
#1122
do you get compression as soon as the piston starts to close the exhaust port?
checkin for fuel blockage is also worth doing, take the glow plug out and spin the motor, if your at factory rich settings you'll hopefully see a visible spray of fuel exiting out the glow plug hole.
#1125
I have a Mugen X12 with the grey head, is the piston and sleeve still available for this engine? I don't want the micro cast piston. Any part numbers? Anyone know where it is available?
Also here is the part number (F08613B) for the piston/sleeve & rod set I run in my stock X12 and JPX12. It is the JP-FX12 modified piston and sleeve. This is what I have been running all year.
Troy
