Tamiya F104 Version 2 >
Like Tree2Likes
Old 01-28-2013, 10:37 PM
  #886
Trader Rating: 20 (100%+)
Thanks for that Roy. Will have to rebuild the diff tonite.
bee200sx is offline
Old 01-28-2013, 10:41 PM
  #887
Pro10noob's Avatar
Trader Rating: 13 (100%+)
Your welcome.
Regards Roy
Pro10noob is offline
Old 01-29-2013, 06:47 AM
  #888
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Thanks roy.
Finally raced the f1 with other 3-4 pans cars. What a blast it was to drive and what a difference paragon fx2 makes. Went from babying it to half throttle in turns and full at exit...cant wait for more driving
This was with the very same hard pits tires that im having issues at another track
Mr.juarez is offline
Old 01-29-2013, 07:18 AM
  #889
Originally Posted by Mr.juarez
Thanks roy.
Do you use the paragon FXII on rubber tires?
And is it the basic and then use another tire additive on top of it or is this the only tire additive you need?
addicted2blue is offline
Old 01-29-2013, 11:15 AM
  #890
Mr.juarez's Avatar
Not sure as im not an expert in additives. All I kn ow is that I ran it first heat with out anything, it was 55 degrees outside and I had no steering and rear traction was hit and miss.
2nd heat comes up without paying attention so I had only put the paragon fx2 for maybe 3-4 minutes on all 4 tires before I had to wipe it off and rush to track. Then I was oversteering and had tons more grip.
3rd I added paragon and put tire warmers, I traction rolled 2 times on outdoor asphalt.this is by far the best traction ive had until my lipo dumped because I forgot to charge it after the first 2 heats
Old 01-30-2013, 09:54 AM
  #891
Here is a picture of the new F104 Ver.II PRO titanium version
Old 01-30-2013, 10:56 AM
  #892
Mr.juarez's Avatar
Ahhh f1 porn . So basically same crap just allow mount and baby crap color. Is body already painted?
Old 01-30-2013, 11:44 AM
  #893
edhchoe's Avatar
Trader Rating: 41 (100%+)
Same crap + aluminum motor mount and rear carbon piece.
Shoulda included trf damper instead. And 1031/1032 tires instead of the body set.(if the body set is included)
It is still a better buy than f104v2. I will pass on this one and wait for ....
edhchoe is offline
Old 01-30-2013, 12:07 PM
  #894
The body is included and it's a lightweight version.
Old 01-30-2013, 07:53 PM
  #895
Mr.juarez's Avatar
I agree. I too was considering getting another for giggles but I think ill spend it on the new kyosho sct soon.
Hey is the trf bigger shock or same specs? Do all the springs fit it or I need specific ones?
Old 01-30-2013, 09:23 PM
  #896
edhchoe's Avatar
Same as TRF touring car damper. Regular tamiya springs fit.
edhchoe is offline
Old 02-02-2013, 05:38 AM
  #897
celt's Avatar
Here is a picture of the new F104 Ver.II PRO titanium version]
Who am I kidding, I'll own one the moment they come out.
celt is offline
Old 02-02-2013, 09:45 AM
  #898
Mr. MR4's Avatar
Default 53136 One Piece Ball Thrust Bearing
How do you install the 53136 One Piece Ball Thrust Bearing?
Does it replace the diff spacer?
Mr. MR4 is offline
Old 02-02-2013, 10:05 AM
  #899
Pro10noob's Avatar
It replaces the ballbearing.
regards Roy
Old 02-02-2013, 10:54 AM
  #900
Mr. MR4's Avatar
regards Roy
Thanks Roy
Mr. MR4 is offline
