This is the waterfall fan mount brace that I used along with a Novak 30mm fan
http://www.amainhobbies.com/rc-cars-...ri2001/p468572
Moderator
I used that same brace with a Windy WTF fan and the stock body was obviously not close to fitting. I've been eye-balling a few others at the track (sweep and finisher look the most promising) but I haven't actually tried any on my car yet. There's a trophy race this weekend so I should be able to ask around and test fit a few.
2) dunno
3) I never found my stock mounts to move in the slightest. The Jcon piece is a good looking piece for sure, but it's just bling to me.
Looking at getting a kit soon to race at The Warehouse Hobby raceway in Helena, AL. The track is a medium size I would feel comfortable guessing. I have raced Touring Cars and VTA but have never tried dirt. I will be racing in mod buggy class.
My question is that the minimum weight for mod buggy is 1500g. I am torn if I should go with the Factory Lite or the Champions Edition? Will I miss having the extra weight of the Champions Edition or would the Factory Lite be a better choice because the car will be closer to the minimum weight?
Thanks that's good to know. I just saw Trinity released a fan mount that goes over the endbell... I may just try to use that instead.
It's about flex. I recommend the champions edition and buy a Lite chassis. Try both chassis and pick the one that feels best to you.
On the weekend I noticed a lot of slop in my steering. Traced it back to the servo arm moving. Took it out and found the screw was loosened. I have a Protek aluminum servo horn and pt a washer on and some purple threadlock.
In my next race I had my fastest lap & time on that track. The next two races my pace dropped back again and noted the servo arm was a bit sloppy again.
Was it a fluke, how important is a bit of slop in steering. When I got home I ordered a star washer and will lock it down. Blue threadlock too.
I've become paranoid about steering slop and want your opinions on 3 things;
1) how important is eliminating steering slop.
2) exotek make a specific AE 10th scale aluminum arm, is it any good.
3) the jconcepts centering servo mount is this a useful bit of kit or just bling. Does the servo move with stock mounting?
Whilst I can't comment on the b5m as I don't have any steering slop at least that I'm concerned about I replaced the stock steering rack on my b44.2 with the jconcepts aluminium rack and the difference was incredible. More importantly it gave me the confidence to drive the car how I wanted to and my results improved.
So my advice is rectify what ever you believe is causing the problem so that you can concentrate on driving and having fun.
If its about flex then the Lite chassis would be better for the job? Dirt is all new to me and sorry for asking so many questions. I believe I'll wait to buy the champions edition due to all the extra parts included unless they are unnecessary. The shocks that are included with the CE seem to be the best for the job.
Weight doesn't matter as much in modified as it does in stock. I'd go with the CE since it has more tuning options in the box. I have the Light, and I've thought about getting the "regular" chassis to try out. CE + Light chassis will be less than getting the Light and buying all the other stuff that comes with the CE.
I have ordered the exotek AE aluminum servo arm. As it has a clamping attachment it will be easier to lockdown. I really like the fact that it is designed with the exact dimensions of the stock arms. My OCD in me doesn't like having to add subtrim. This servo arm is 4mm shorter than the one I'm using. Fingers crossed for 0 subtrim.
In regards to the jconcepts servo mount, I decided against picking one up. I thought about it and will replace the washers with star lock washers. Even though I doubt the servo moves often ( really big hits excluded) the star washers will assist in locking the servo in place. The stock servo mounts are more than acceptable. Also don't want to add any more weight to the front of the vehicle as traction can be a bit low at times in Oz.
