New Yokomo TC, the BD-5 >
Old 01-25-2011, 01:36 PM
  #2536
jackdani's Avatar
Originally Posted by Nico'
Hi,
allright, thanks a lot, I understand, I used to think only to tape at the vetical of the hole, but when I go out of the hole with the tape, I can go a little bit inside then put the battery on the tape and finish taping it, so the battery will be placed as if the 20g weight were there.
exactly!
this is what i ment!!
i m sure u will be fine!
let me know, nex time i tape we can exchange pictures if you like!
jackdani is offline
Old 01-25-2011, 07:53 PM
  #2537
How would this car compare to a 417? I'm looking for a second mod car to run this summer. Always been a huge fan of Yokomo and that high traction chassis looks hot. I run a 416x and i just bought a 417.
M3dreamin2008 is offline
Old 01-25-2011, 08:08 PM
  #2538
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by dawgmeat
Whats parts do i need to use X-ray ECS drive shafts?
please read back a few pages. the hardest part is getting the xray chubs working with the arms. everything else you need is documented at www.sidepieceracing.com
hanulec is offline
Old 01-25-2011, 08:10 PM
  #2539
dawgmeat's Avatar
Leaning very heavily towards the BD5, when ordering spares should I get the plastic or LW Suspension parts?
dawgmeat is offline
Old 01-25-2011, 08:11 PM
  #2540
dawgmeat's Avatar
thanks
dawgmeat is offline
Old 01-25-2011, 09:50 PM
  #2541
dbworms's Avatar
Hi guys,
Just got my BD5 and finished assembling it. Excuse my BD5-noob question but I'd like to know how to secure my battery. It's a common stick type and doesn't fit the holes at all. Will the 3 racing battery holder fit? Also, is it safe to (quick dry) glue plastic pieces on caron fiber to DIY a battery holder?
dbworms is offline
Old 01-26-2011, 12:13 AM
  #2542
Nico''s Avatar
Originally Posted by jackdani
hi nico where are u from?
however i had you problem too,
as i m using flat batteries.
solutions i used are two:
-i glued a small square of carbon under the batteries so that it will fit the hole
-if you don't want to glue it u can use the tape not only in the front-to-back direction but also in the left-to-right direction because as you can see the chassis has 4 holes for the tape.
this is how i tape:
Hi,
it's how Jackdani explained me how to tape, it's a way I will use next time.
when you go out from the hole with the letf to right tape, go a little bit inside , put the battery on the tape and then finish taping it.
Jackdani, Allright of course, I'll will make picture and exchange with you, thanks a lot.
Nico' is offline
Old 01-26-2011, 03:48 AM
  #2543
defcone's Avatar
Trader Rating: 15 (100%+)
I switched to the plastic parts from the LW parts and haven't broken as many C hubs and steering knuckles. Arms I use the LW ones and haven't broken any in half a year racing a mix of 17.5t/10.5t/Mod.
defcone is offline
Old 01-26-2011, 04:39 AM
  #2544
jackdani's Avatar
this looks nice!
http://www.redrc.net/2011/01/yokomo-...up/#more-38864
good luck drivers!
cant wait to see next round of ETS!
jackdani is offline
Old 01-26-2011, 04:44 AM
  #2545
jackdani's Avatar
does someone know where to find this sway bar mounts?
i used to think they were only for long bars, but as i see they are not!
they are really a good piece, any ideas??
jackdani is offline
Old 01-26-2011, 06:59 AM
  #2546
Nico''s Avatar
I bought mine at Asia Racing Team , in France but out of stock today.
http://www.asia-racing-team.com/shop...cc9417ef806141
this item is very useful I think.
Nico' is offline
Old 01-26-2011, 08:57 AM
  #2547
jackdani's Avatar
cool, i cant find it in italy!
can you tell me the difference with the normal 2 points holder and why it is better, Nico!?
maybe because it is simply to regulate the bar?
tnx
jackdani is offline
Old 01-26-2011, 09:18 AM
  #2548
Nico''s Avatar
Hi,
first I think that the original mounting is a little bit boring and then with this aluminium part the mounting is very easy and sure to be well done.
And this part is beautiful too ;-)
Nico' is offline
Old 01-26-2011, 09:33 AM
  #2549
jackdani's Avatar
Hi,
i agree, this is very beautiful for sure, i wanted to know if it is even useful!
however the mounting should be easyer, i will buy them nex time i need something.
i ll send you pics of my built!
jackdani is offline
Old 01-26-2011, 05:32 PM
  #2550
kschu's Avatar
Trader Rating: 16 (100%+)
aluminium sway bar holder make mouting and sway bar adjustment more easier....
but if u hit hard or other car hit u from behind, it'll bend the holder..
Roche released new Belting for Yokomo BD5...Low friction...most suitable for stock class racing as it's less dragging and gv little more rolling speed to the car in Off Throttle.....
kschu is offline
