Adjusting diff. in car??
Sorry for the newby question, but I want to adjust my ball diffs while they are in the car (a Yokomo MR4 TC). On my old XXXS I could lock one side with an allen wrench, but I'm not sure if there's an easier way especially with the Yoke, which has a little bit different diff.
If there are any good tips for doing this, I'd really appreciate it!
Thanks,
Tony
Thanks,
Tony
Super Moderator
Well, I believe it goes together just about the same way as the TC3's diffs & gearboxes, so you might be able to adjust it the same way, by removing the wheel on the side of the diff where the adjustment screw's head is, then popping off the turnbuckle on that end(the camber link) & let the hub pivot down & away, then you may be able to reach the screw with a sufficiently long allen wrench.....
