Funny picture!!!
Funny picture!!!
So, 16 plus minutes into the 20 minute A-main.... I am a lap down on first and a lap up on third so just pushing hard enough so that if first place crashes or has a problem, I'll be there to capitalize when out of the blue-traction roll, car does one flip onto its lid and goes 35 -40 mph backwards into the pinned down 2x4 boards!!! Loud crack-DOH!!!
Car is half over boards, but body is inside out and flipped over like an omlette!!! Heres the funny results!!!!HOpe you enjoy the pic!!!
OUCH,
gotta love the TC3....
Looks like you need to use weaker body post pins....then you can have an "ejecting" shell look!!!!
hahaha....good one!!!!!
Race Ohio
Yup-and the race was going so well up till then!!! I was not the fastest, but was good. Car was tipping a little first lap or two-then settled down. Then just flipped over!! I think maybe I was a little wide entering corner and went full lock to get car to apex and that extra force traction roled the car. Bummer!!!
hey man,
where do you race? mentor? i've been up there these last few weeks. which club? later.
Pinned 2x4s huh? Pinned for the whole track or just the outer boards? My only experience with a pinned board track taught me to bring a lot of spares and to inspect the car extra carefully if you hit anything. I can see how you're compressing the toe links now. It sounds as if the MORR track has a lot of traction, what do you expect it to be like this weekend? better? Also how is wear compared to Toledo?
Some pinned some not!!!
The track has both pinned and not pinned sections. The ends of the boards are not pinned so you can hit them and go on (and block the track for those chasing behind you!!!)
MORR has less traction because they just laid the seal down and we have only run on it once. Tire wear is higher than Toledo. But I fully expect by Saturday night, the MORR track will be very grippy and tire wear will go way down.
I was going to test and see if I could make my car work on harder front and rear tires to combat tire wear in 20 minute main, but I dont think it'll work.
