What's your input on 1/10 Electric Touring Min weight? >
View Poll Results: What's your input on 1/10th tc minimum weight?
1420 grams
80
51.95%
1500 grams ( Current ROAR)
18
11.69%
1450 grams ( same as IFMAR)
56
36.36%
Voters: 154. You may not vote on this poll
Old 08-11-2009, 04:30 PM
  #16
Originally Posted by or8ital
What car and what size lipo?
Phi '09. I saw your other post about balancing the phi; I had the same issue. With the lipo tray, I could not balance my car at or around 1420 grams with a larger 5000+ lipo. Mabye there is another solution to the 40+ grams lipo tray.
samstheman2 is offline
Old 08-11-2009, 04:42 PM
  #17
Trader Rating: 38 (100%+)
I was thinking I could cut the middle out of the outside part of the tray. But until the weight is finalized and used everywhere I race I'm hesitant to do that. Plus not sure how much that would really save me. Maybe only 20 grams. Would still need to find 35 grams somewhere.
or8ital is offline
Old 08-11-2009, 08:06 PM
  #18
liljohn1064's Avatar
Trader Rating: 17 (100%+)
If the lighter weight means less breakage, I'd say sure to 1420. But I think I'd rather have a slightly beefier chassis, so 1450 as a world standard would be fine. Put the extra mass in the parts that need reinforcement. Definitely 1500 for TA!
liljohn1064 is offline
Old 08-11-2009, 09:02 PM
  #19
niznai's Avatar
I think this is not a real problem. If you want to race an overweight car nobody will stop you. Sure, top racers will chase the latest and greatest and try to be as light as possible but this can play against you very easily.
We have to keep in mind as well that Lipos are an atypical development in battery technology. I am not sure that future batteries will keep getting lighter at the same rate as lipos did (i.e. they came out right after Nimh which are rather heavy). I don't know for instance how LiFe batteries stack up against Lipos weight wise for similar charge capacities, but if they are the next big thing in battery technology and happen to be heavier, then a lot of people will have a lot of trouble keeping close to a reduced weight limit. This in turn might push manufacturers to lighten their cars and again top level racing will become a money competition.
That being said I think either of the weight limits mentioned here are acceptable and shouldn't make that much difference. The only possible situation where they will make a difference is in conditions of really low grip (rubber on carpet for instance) and then people are free to find their own way to deal with it. For relevance I would vote to keep weight specs to limits drafted by international bodies, but even these seem to not agree with each other.
niznai is offline
Old 08-11-2009, 09:55 PM
  #20
JimmyMac's Avatar
I like it (1420g). Got my Yokomo BD5 balanced with my TP5000 40C pack with 9551, 17.5 motor, Tekin RS Pro, and Spektrum rx.
JimmyMac is offline
Old 08-11-2009, 11:45 PM
  #21
SammyZ's Avatar
Trader Rating: 138 (100%+)
i get my cars to balance perfect without using any weight, with body they scale out at 1250g
To bad its not legal
SammyZ is offline
Old 08-12-2009, 12:41 AM
  #22
It would be good to see any weight limit under 1500g. It would be nice to not need around 120g just to make my car legal, and its still under weight with out a transponder. Only 45g of that 120g is for balancing.
Scooter79rs is offline
Old 08-12-2009, 02:40 AM
  #23
Just to let you know, the IFMAR weight is 1450g but their current rules are for 5 cell NiMH - so not 100% relevant perhaps?
In the UK the biggest regional series (100+ entries for each of 8 events) is running 1450g weight limit. This seems to work very well, its fairly easy to make the car balance at this weight and requires perhaps 100g-150g of weight, depending on your LiPo size and the electronics you are using.
Seems to work and we are expecting this to become the 'standard' weight adopted across the UK next year.
Bigger Brother is offline
Old 08-12-2009, 03:12 AM
  #24
I have been told that OZ will be going to 1425g next year too. I am not looking forward to this as this will require me to change electronics and possibly ti screws to get the weight down enough to achieve my current f/r balance. The other negative is that entry level chassis like the tao5 are currently getting down to weight with lipos. This will not be the case with 1425g and certain electronics.
Lipo's brought forward an era of equal battery power and weight across all chassis and racers. It would be a shame to lose this equal playing field. And the increased lap speed of less weight will serve to spread the field further.
Dragonfire is offline
Old 08-12-2009, 03:29 AM
  #25
paraletic's Avatar
Trader Rating: 13 (100%+)
i agree i think that 1425 is to big a drop in weight i run a xxxsg+ and now with lipos its only just scraping in at the 1500g mark i think it would really make it a lot harder for the guys running older cars to be competitive
paraletic is offline
Old 08-12-2009, 04:14 AM
  #26
tc3team's Avatar
1450 sounds like a happy medium to me
tc3team is offline
Old 08-12-2009, 05:41 AM
  #27
The speed difference between a car at 1500 and 1420 will be significant. Noticeable by most drivers not just the top ones. It makes a bigger difference then you think. People who think cars will break less at 1420 are forgetting that the car will be going a lot faster. They will break just the same.
or8ital is offline
Old 08-12-2009, 07:17 AM
  #28
seaball's Avatar
fairtrace and schreff have run their losi cars at as much as 2 ounces over wieght (60g) and have tq'd and won national races in that trim (schreff accidentally grabbed a heavyweight body two years ago for his tq run in stock at the snowbirds). it's noticeable, but let's not go overboard.
but you're right about breakage. not because the cars are faster, persay, but because 90+% of crashes probably overshoot the yield point of the failing materials by 2-10 times the yield value of the material. therefore, a 5% difference in mass isn't inline with the magnitude of forces/impacts exerted durring a crash. forget the theory, and get real. when you come back with a broken arm, bent dogbone, and your chassis is twisted like a pretzel, i can tell you -80g wouldn't have saved you.
(it's as if people don't even remember how bad they wreck when they say half of this stuff)
I've been a big fan of what ROAR has been doing lately but I hope this doesn't become a standard rule.
as a big fan of roar, what roar races have you run lately? how will this rule affect you? is your local club that highly enforcing of roar rules?
Originally Posted by TimV
I like the 1420. However, I think the min weight for foam tire sedans need to be addressed. The rubber tire cars are now at the same weight.
this would be a purposeful move, i suspect. with 3-4mm lower chassis plates, thicker top decks, and the mandatory gbs (0.030") bodies, foam cars don't really come in much lighter than their rubber counterparts. i like the standard number for both classes, even if one is slightly easier to achieve than the other. the general idea is to simplify things (from finding places to add weight to memorizing one minimum number).
seaball is offline
Old 08-12-2009, 07:49 AM
  #29
artwork's Avatar
Trader Rating: 88 (100%+)
I just wish that they would leave the weight at 1500grams and make the cars a little heavier. Let's put some weight in making the cars more beefy and then getting to 1500 wont be such a chore. Instead what is happening is that cars are getting lighter and more fragile.
The cars being designed outside the US (which is almost all of them) are designed to run tracks with no hard boards. Most of the tracks have curbing and or dots. Here in the us we use the hardest boards ever made to design our tracks so we tend to see breakage that they never see in the design and testing .
simply, lets keep the weight at 1500 and work on creating better cars across the board. Anyone that has run a newer style nitro car know that it is possible, we just need the manufacturers to get on board.
artwork is offline
Old 08-12-2009, 08:18 AM
  #30
The HPI Challenge doesn't have a weight rule so I've removed all excess weight on cars for that. I was significantly faster at the lower weights. To the tune of .2 a lap faster. So for me, a slightly above average race, it was pretty significant. Excess weight in the right places on certain cars might provide some benefits though. I know people were saying some VTA cars got faster with more weight so it's all about setup as usual.
Our track follows ROAR rules, as do most clubs it seems. They are the defacto standard for rules in the US, which is a great thing. Otherwise you couldn't easily travel to other tracks. Locally we have a lot of people who do race in ROAR events so they try to keep them in line to help those folks out. Would be ashame to practice one way and then race at a national event another. Wish I could have gone to the Nats this year. Still may if I can get a scheduling conflict resolved.
or8ital is offline
