Losi 1/8 8ight E 4wd Thread
#4306
#4309
Should have my buggy next week. running a 1900 tekin on 4s with a 45 spur, what should i be running for a pinion? want to make sure heat is not an issue.
#4311
thanks, one of these days i want to try a 1700 or even lower, definitely dont need the 1900 around here
#4313
Who makes a 14.5?
#4314
#4315
Hi guys,
I'm running a converted 1.5 8ight with the original motormount. But every time I race it my mesh is looser. I need to reset it every 2-3 races... The bolt is tightend really good and I did threadlock in it, but nothing seems to help.
I'm running a 2200kv castle neu with the motor brace (which I had to modify a bit) geared 14/48 or 13/45. Stripped my delrin spur last weekend, because my moved away from the spur...
Do you guys have a fix for this? Also sometimes is hard to get the motor out of the mount when I drove it a few times without taking the motor out every time...
#4317
There seems to be no difference between running a brace or without. The mesh always comes a bit looser.
#4318
I run it since I stripped my spur last weekend. I tought the mount was comming lose because of the big hits with the ground. Also, some of my finns from my motorcan were damaged because they hit the chasis without the brace
#4319
Can I ask you what motor your running? The 1515 1.5Y is pretty heavy compared to a tekin buggy motor. Maybe that makes a difference too. I think I'll buy a neu 1512 of a tekin motor/combo next month.
But does your stays good, or do you need to reset very often?
#4320
Hi guys,
