Losi 8ight building and setup >
Old 12-17-2008, 12:24 PM
  #8071
MikeFriery's Avatar
Trader Rating: 19 (100%+)
Originally Posted by dodgeboy93
hey do any of you guys balance you buggies (like a touring car) and does anyone use set up stations or just use a camber gauge and toe gauge.????
I've never found the need for anything other than a ride height guage, and a camber guage.
MikeFriery is offline
Old 12-17-2008, 05:59 PM
  #8072
anyone know or have info on the smart diffs,??
#1 is there going to be rear one?
#2 they offer a 90 degree & 120 degree ramplates what are these for?
#3 they also have an assortment of return springs used how?
Here is the info on the Smartdiff off of Losi's site.
http://losi.com/ProdInfo/Files/smartdiffman.pdf
I'm still trying to understand it myself....
Bogi is offline
Old 12-19-2008, 10:34 AM
  #8073
dodgeboy93's Avatar
Default smart diffs
thanks bogi thats what i needed!!! but they dont offer a rear diff assy. does anyone know why??? IM ASSUMING THAT ITS NOT NEEDED??
dodgeboy93 is offline
Old 12-19-2008, 11:20 AM
  #8074
Integra's Avatar
you would not want a rear smart diff as when you applied the power out of a corner it would lock up the rear end and cause a Spin out.......the concept of these diffs have been around a Long time..this is just losi's version of them...most racer's would not benefit from one of these imo.
Integra is offline
Old 12-22-2008, 01:33 PM
  #8075
underthethumbma's Avatar
Default hi all
i need so expert help befor i go mad i am running a sirio cl3b in my losi buggy and no matter what i do i can not get the linkage to pull straght and my carb keeps binding up..... dose anyone run a sirio motor in there losi can you post some pictures of how your linkages are set up i have noticed the carb is angled a lot more forward than on my s7 would this make a difference HELP
underthethumbma is offline
Old 12-22-2008, 02:43 PM
  #8076
K_B
K_B's Avatar
Trader Rating: 70 (100%+)
I don't have a Sirio, but on mine (and many others I've seen), it does help to angle the carb a bit. The linkage needs to pull straight out relative to the carb. So the linkage needs to be lined up straight with the carb. As long as the linkage is at the same (or very close) angle as the carb, it should slide without binding.
K_B is offline
Old 12-22-2008, 02:57 PM
  #8077
Trader Rating: 22 (100%+)
converted my 8ight to the dark side
I still do nitro though.....
phixd is offline
Old 12-23-2008, 08:02 AM
  #8078
Interesting to see you're using a flywheel/clutch bell and a brake servo. I guess you didn't like the braking provided by the motor and ESC?
stevoreno007 is offline
Old 12-23-2008, 08:55 AM
  #8079
Trader Rating: 11 (100%+)
I run an Extech, which is a Sirio based engine. You need to Dremel the top brace for the center diff to get enough clearance to rotate the carb. Mine is Dremeled all the way back to the post, there should be a pic of it a few pages back. Then rotate the carb until the linkage is as straight as you can get it. BE SURE that the linkage is straight when the throttle is all the way open, it will bind if you don't. You also need to be sure that the linkage is level with the servo.
cjtamu is offline
Old 12-23-2008, 09:41 AM
  #8080
K_B
K_B's Avatar
Some people want to retain the brake bias feature, others do it because they like the "feel". The big benefit of retaining the brake servo is it takes alot of strain off the motor/esc. Lowers the temps quite a bit I would imagine.
K_B is offline
Old 12-23-2008, 07:43 PM
  #8081
Just ordered a new clutch nut and hardware set for my 8B(par no. LOSA9103, amain link: http://www.amainhobbies.com/product_...oducts_id/7953.
Question: it came with two white silicone/rubber o rings, what are they for? When i originally built my kit these were not included.
Jonro is offline
Old 12-23-2008, 07:47 PM
  #8082
Integra's Avatar
No one know's......Not even the guys at Losi...its kinda funny...but w/e...just toss them or keep em for something down the road.
Integra is offline
Old 12-23-2008, 09:16 PM
  #8083
dodgeboy93's Avatar
why did you not use the losi clutch bell?? how do you like that E-conversion compaired to the others??
Old 12-24-2008, 12:01 AM
  #8084
TTR:EB4's Avatar
Wow 3 nights later and ive red all 270 pages hahahaha
accept i cant remember from 267 and back
TTR:EB4 is offline
Old 12-24-2008, 07:36 AM
  #8085
Integra's Avatar
Integra is offline
