Xray T2'008
#1728
another xray T2 008 US spec user here,
pics of my drifter
pics of my drifter
#1731
Has anyone tried to run a 38t spool and diff with the 20t idle gears on a 008 EU, and if so what belts did you use to make it work? Part numbers if possible.
#1732
#1733
305432 - High-Performance Kevlar Drive Belt Front 3 x 513mm (for conversion set)
305446 - High-Performance Kevlar Drive Belt Front 3 x 189mm (for conversion set)
#1734
Does anyone know the difference between the 007 and 008 diffs? I'm picking up a 008 and want to know if I can use or convert the 2 007 diffs I have.
Also, is there a list of parts that are different somewhere so I dont get rid of 007 parts that I later end up buying again??
Thanks.
Kevin
Thanks.
Kevin
#1735
#1736
Thanks.
Kevin
Thanks.
Kevin
http://www.teamxray.com/teamxray/sho...p?file_id=2667
You will find not a lot of parts swap between an 007 and a 008.
#1737
Thanks.
Kevin
Thanks.
Kevin
#1738
You should find a conversion chart on the team xray site with all the cross over parts. Save link as..
#1739
I did installed my 007 diff and got it to work.the belt is off set and there was no rubbing......
I didn't have any problem with the out drive
#1740
Yup, the diffs and spool will fit...not perfect, but definitely acceptable. In fact, most guys here with 007's have the 305184 Composite 008 Spool installed!
