Battery bars
Battery bars
Hi everyone, i would like to learn and hear more stuff about battery bars...in the current market we could see numerous battery bar is available and the battery is important item. CAn anyone tell me more about it...etc like is the plating of battery bar is important, as i can they are copper, silver, gold,and platinum? the platinum is far the most expensive and does the plating have real effect??? or just marketing hype
well EngTat team huricane has the best bat bars around they have the best contact to your cell thus having more power on the track you can find them at http://www.teamhurricane.net/index.html for like 4 bucks or some thing there realy great
I appreciate you may be sponsored by them, but what makes the team hurricane any better than others??
I like either the trinity bars or the orion gold bones....
In theory gold offers a comprimise between conductivity and resistance to corrosion.
The nickle/silver ones seem fine.....
If someone can actually tell me they can feel a difference in ANY of them...I would be surprised.
Team Orion / Peak Battery bars have a "step" on it so that the bar will stay flat since positive pole is usually higher than Negative pole. I tried Deans Pro Bar but they are bigger than Team Orion ones.
After what I learned in Chemistry this year, here's the deal with the plating: When you have a metallic bond (metal with metal), the protons and neutrons remain in the middle of the metal, while the electrons gather on the outside of the metal, creating this "sea of electrons" effect. The electrons are completely free, and they switch atoms at random, so there are no definate electrons surrounding a given atom. So what does this mean? Since it is ELECTRONS that carry electricity, this means that electricity only flows on the surface of metal. Therefore, there would be no difference between a solid gold bar vs a golf plated bar, or solid platinum vs, plated platinum, etc. Now- whether or not gold plating is better than platinum, is arguable. I personally prefer gold because with platinum, you get all kinds of corrosion. But corrosion and side affects aside, I think even the best would not be able to tell a difference between platinum and gold. I think reliability and rigidity trumps performance in this case. So stick with bars that don't break, and don't corrode.
-Josh
-Josh
Dude, what?
Of course the metal effects it. Even if you are sayng that the electricity only goes around the edge (which is incorrect, far too simplistic an answer so I suggest you take physics as well as chemistry) the impedance of the metal contributes to the current flow.
If the voltage is the same, the resistance in the material becomes the main varying factor in current flow.
conducivity of the material is of huge importance, however, in this case the variance between the options available is minimal in my opinion
Originally Posted by BritRacer
Dude, what?
Dude, what?
-Josh
EDIT: BritRacer, I take physics next year.
I agree, plating is different from solid metals. BUT you stated that the internal metal did not affect things at all. This is untrue.
Well then if electricty travels on the surface then how can the internal metal affect it? Please explain.
-Josh
-Josh
now where did i put my gold plated popsicle sticks
(no real value, just had to. i use deans bars)
There is much more to electroplating and anodization that what you learn in one day elementary chemistry....
If the current would only be carried through the plating surface (plating) the resistance and current handling capabilities would be AWFUL...
The plating is so thin that it is mainly for LOOKS. You are talking microns…
I am not going to get into the chemistry and physics, but if the current would be handled only by the plating, you could only support milliamps, not currents in excess of 50A.
The most important thing with solder bars is the connection from the bar to the battery.
You can have solid GOLD BARS but if the solder joint is bad, the advantages of the GOLD would be wasted...
There IS NO DIFFERENCE between ANY OF THE GOOD BARS OUT THERE.
I sell bars and I AM NOT PROMOTING OUR BARS...
Just buy any good solder bar and USE GOOD SOLDER AND SOLDERING TECHNIQUES.
How many of you have actually measured the voltage drop across the bar...That alone will tell you which bar is the BEST ONE.
If you have two batteries that you can throw away do this test:
Take two batteries, connect the two of them with one battery bar and then use a 0.01 ohm resistor to close the ciorcuit, then measure the voltage across the battery bar. Assuming that you have 2.4 volts, the bar would have 24 AMPS flowing across it. Divide the voltage drop by the current and that will give you an aproximation of the bar' resistance.
As long as your solder connection is done the RIGHT WAY, there is MINIMAL DIFFERENCE. You develop a larger voltage drop across the battery/solder bar connection than across the entire solder bar.
And BTW, there are more chances of corrosion due to the use of ROSIN FLUX than from anything else in the bars. ROSIN RETAINS WATER and in humid places the accumulation of condensation creates a corrosive environment.
IMO
IMO
